Bushwhacker Air said:I agree with what you said about the cabane V ears in the other post, Mike. Piper never meant to have the washers welded all the way around - I would imagine it weakens that ear a little. The gear attache is pretty tough.
what would be a good simple project I never got to, and easy for someone to produce(who has a pma program already) is a bolt on doubler plate that goes on gear fittings from gear bolt to cabane bolt.....
Bushwhacker Air said:what would be a good simple project I never got to, and easy for someone to produce(who has a pma program already) is a bolt on doubler plate that goes on gear fittings from gear bolt to cabane bolt.....
I already have the tooling for the compound bend - probably a .063 plate would work. Add this to my list of things to do :-?
Living in New York, I rarely see SC injuries - just 1 that I have had the pleasure to work on, and the was a float accident with little fuse damage.
mike mcs repair said:Bushwhacker Air said:what would be a good simple project I never got to, and easy for someone to produce(who has a pma program already) is a bolt on doubler plate that goes on gear fittings from gear bolt to cabane bolt.....
think it would sell good, and probably be a minor installation???? bolt on.....
Darrel Starr said:How about stainless steel dumbbell shaped loose piece that fit in front and behind the cabane ears like washers under the two bolt heads?
Darrel
Alaska_Rallyer said:Why not install in on the backside, give it an extra ear with hole, and use it for your safety cable bracket/attach point as well?
Today I discovered a crack on the gusset on the left front landing gear bracket. I have the Atlee-Dondge safety cables, and the metal tab for the safety cables was ground off so it would clear the gusset. It looks like the metal tab was pushing hard against the gusset. The rest of the bracket appears to be fine, as in no cracks around the bolt holes for the cabane or the gear strut and no other visible cracks. There is not a gusset on the right front bracket. My cub is a PA18A-150. Is this gusset from the factory? How do I fix it? Any help is appreciated.
Mike
