Results 1 to 7 of 7
Thread: Wing strut identification PA-18
    Mar 2005
    325
    I do not have logs on these wing struts. Are there markings that i can find or are there differences between the manufacturers.
    mike mcs repair's Avatar
    11,773
    univairs lifetime have 5/8" forks are cad plated.... and a circle "U"on upper fitting mark... not sure on later forks..
    Airframes lifetime have 5/8" stainless forks only I think.....
    21,305
    "U" with and "A" in it for Univair Aircraft stamped at the wing attach end like Mike said. Univair started using stainless forks a few years ago.
    Mar 2005
    325
    Thanks. I will let you guys know what i find.
    I was hoping that one company has different welding or construction techniques that are obvious when looking at them.
    Mar 2005
    325
    Ok you are all right. The Univair struts are easy to spot with the stainless forks and the U stamp clearly on them.
    The other obvious difference is where the fork screws into the strut. The struts in my first post are Airframes with a very smooth appearance. The Unavair struts have a protruding plate within the weld. THANKS
    Univair struts
    Lebanon NH
    137
    Steve do you know if Univair makes longer 5/8 forks? Also would they make longer PA-18 lift struts?
    11,773
    Quote Originally Posted by Clifford View Post
    I bet Airframes would make you a longer strut.... Don't ask how I know they have this capability.....
  1. wing strut
    By lunchmoney in forum Cafe Supercub
    Last Post: 10-25-2006, 08:15 PM
  2. Wing strut AD. note
    By Thom in forum Super Cub Sick Bay
    Last Post: 08-10-2002, 11:49 PM
