Results 1 to 5 of 5
Thread: Control Surface Deflections
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    449
    I am installing a PA-18 tail and flaps in my PA-12. I cannot seem to find the required control surface deflections, i.e. how many degrees do the controls have to move up and down. Can anyone help? I need the figures for the elevators, rudder, flaps, and ailerons.
    Thanks!
    Bent
    Oct 2003
    Hartford, Wi. HXF
    70
    Try doing a search on the faa.gov site for type certificate data of the model your interested in. Should all be there!
    behindpropellers's Avatar
    NE Ohio
    6,805
    Bent-
    rgl.faa.gov
    http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/45b0fe3b1c17780186256a61006c7931/$FILE/a-780.pdf
    That is the PA-12.
    For the flaps you want them to go down 40 degrees from zero.
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    449
    Thanks Tim,
    I am installing a 150HP engine per the Kenmore STC. Will the elevator deflections for the PA-18 elevators and with this engine be the same as the unbalanced, original ones are with the smaller engine??
    Bent
    NE Ohio
    6,805
    Quote Originally Posted by BES
    Thanks Tim,
    Bent
    Bent-
    I do not know for sure but: If your STC says that the deflections are supposed to be xx up and xx down then make it that way. If there are no specific instructions like that then use the TCDS.
  1. Control Surface Travels
    By Roger in forum Super Cub Sick Bay
    Last Post: 05-24-2004, 01:20 PM
