Mag Cooling Question
gdafoe
My engine is installation in a O-340 Stroker. The exhaust is Brian Sutton's system located up front, not in standard cub rear location. Do I need blast tube cooling for the Mags?
What is the best way to attach the blast tube to the rear baffle. Is there a fitting (flange) that fits 5/8 or 3/4 inch tubing. Does someone make an assembly for that purpose.
Experimental . .
How 'bout just taking that tubing & splitting up an end & riveting it to the back of the baffle? Doesn't haft'a be airtight, right?
