Page 1 of 2 12 LastLast
Results 1 to 40 of 50
Thread: Carb Control Cables
    Sep 2002
    248
    Carb Control Cables
    Bought some of those cable anchors from Spruce and am planning the best way to locate them
    Have a MA4-5 for my 0-360
    Anyone have any good pics of how you rigged your control cables and what you used?
    Sep 2002
    248
    Got Pics????
    Sep 2002
    248
    P.S. The carb end not inside
    20,190
    Are talking about these?
    gdafoe's Avatar
    883
    How about this?
    Gerald
    Sep 2002
    248
    Gerald
    Thanks for the picture trying to get the best mount ideas
    Also looking for a pic to see which way to route the starter cable
    Anybody have more pics would be great
    Snert's Avatar
    Mar 2006
    Raleigh, NC
    1,763
    The hose clamp holding the blue bracket to the engine mount bothers me a little. I would be looking for something more substantial. Then, what do I know?
    10,679
    I would be concerned with the possibility of a rough running engine because the throttle is anchored to the engine mount and the engine can move separately because of the shock mounts, thereby changing the throttle setting when the engine shakes. This would give you a fluctuating rpm. The throttle cable should be anchored to the engine not the mount.
    20,190
    Here is a stock 1982 Super Cub throttle linkage. There is a clamp welded to a stand-off which is clamped to the engine mount. I will look in my factory pictures for a better view.
    gdafoe's Avatar
    883
    On my factory cub the throttle cable is anchored to the engine mount. With a rather weak factory part. (see Steve's pict, mine was similar) Never noticed it jumping around a whole lot.
    On the hose clamp, I thought the same thing until I tried it. There is a lot of difference it hose clamps, tried a few, Breeze makes the good ones. Of course you can only see one leg of the mount in that picture.
    Gerald
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,362
    Vans makes a bracket plate that bolts between the sump and the carb, which then gives a place to anchor the throttle, mixture, and carb heat. I believe it is depicted on their website. Oops, they don't have a picture but here is a link to the plate
    http://www.vansaircraft.com/cgi-bin/...rottle-bracket
    Hope this helps
    Sep 2002
    248
    appreciate the pics keep em coming. Looks like i will fab up my own bracket to support the throttle cable. I've got 4to1 exhaust and will have to include heat sheilding
    Anyone run a seperate ground cable right up to the starter? Want to increase maximum power to my B/C light weight unit
    See if you can include a pic of the batt cable routing no Cubs in my area
    9,346
    I will get a pic today, if I remember... mad cow and all.
    FYI: I don't see any tape or chafe material between the mount and the clamps or clamping system
    Am I the only one that worries about the vibration causing weak spots on the mount?
    Put a plastic tie around the mount for 100 hours and it takes the paint off... think about what it wears next
    20,190
    Talked to Kosola (the folks that overhaul engine mounts) recently. The lady there told me you would not believe what wire ties do to engine mounts.
    bearsnack
    Guest
    Thin brass shims work well under those clamps.
    JayH's Avatar
    Mar 2005
    NE Iowa
    269
    I want to revive this thread a bit as I'm trying to run and position the carb control cables. Ware issues with metal on metal scare me little as well. It seems the factory didn't have any problems with mounting throttle cables to the engine mount, however the issue is engine vibration in the rubbers vs fixed mount causing throttle creep etc....I have an O360 which would vibrate quite a little more. Has anyone seen or have pics of that Vans bracket Bill Rusk mentioned? Any new insight on this topic or fancy new brackets, ideas, or photos? Thanks!!
    J
    spinner2's Avatar
    Montana
    1,789
    JayH's Avatar
    Mar 2005
    NE Iowa
    269
    Spin,
    How is the aluminum angle attached to the engine mount? Is it adel clamps or...? Looking like the engine mount in that location is gonna be the way to go I guess.
    J
    11,534
    fyi what ever you do, make sure with cable disconnected at throttle arm that it is relaxed in idle and full throttle position or it will immediately creep up off idle if in tension there
    the crosswindsstol 180 engine install uses ONE aeroseal? winged thumbscrew hose clamp with a hole in end of wing for each cable, throttle included......STC'd 40+ years.... kinda scary looking..... so when you start over designing things, might look to whats been out there already.....
    spinner2's Avatar
    Montana
    1,789
    Quote Originally Posted by JayH
    Spin,
    J
    Steel clamps to motor mount tubes.
    No problem with flex in cable causing throttle creep. But after the picture was taken I did move the throttle arm attach bolt to the top hole to get full travel.
    JayH's Avatar
    Mar 2005
    NE Iowa
    269
    Thanks Spinner.
    Mike, now that sounds interesting, would like to see a photo of that operation.
    supilot's Avatar
    49WA
    474
    Does someone make these mixture cable brackets or do guys just weld them together? P/N?
    3,712
    Looks a lot like some factory brackets I have. I had to fabricate my own though, when converting to a short mount on my 12. A call to Univair might be worthwhile - -
    20,190
    Univair has them:
    12408-000 Clamp Assembly- Throttle Control $97.85
    12407-000 Clamp Assembly- Mixture Control $64.43
    Or you can Jake Leg it with Adel clamps and it will slip all over the place in time.
    20,190
    I'll send you a parts manual with the next special surprise from Lee.
    supilot's Avatar
    49WA
    474
    Thanks all...it must be made of gold or platinum.
    Steve, I'm good on special surprises. Returns yellow in color aren't accepted.
    Mar 2005
    Normandy TN
    314
    The Van's bracket goes between the carb and sump and uses an extra carb gasket. They list it to fit 0320 ande 0360's would it also fit a 0235? Are the carb/sump
    bolt patterns the same for 0235 and 0320 carbs?
    JM
    20,190
    Yes, the patterns are the same. Looks like a good alternative for experimental.
    Bushcaddy's Avatar
    Jul 2009
    Marshfield, MA
    39
    The bracket from Vans will not fit an O 235. The bottom of the O 235 oil sump that the bracket sits against is different than an O 320, there are also a few other subtle differences. The brackets from Vans only work if there is substantial room between the fire wall and the engine. I have an O 235 on my plane and had to fabricate brackets like those above in this thread. Took forever to get them right.
    Clark's Avatar
    Oct 2010
    12
Name:	Vans Bracket 1.JPG
ID:	4133Click image for larger version.
Name:	Vans Bracket 2.JPG
ID:	4134 This is what the Van's Bracket looks like. The attached photos are showing the top surface that fits up against the sump & the carb fits on the underside (gaskests on both sides). This bracket fits a 360 - I don't know about the 235
    20,190
    I couldn't see any difference between the O-235-C1 oil sump and the O-320-A series that I have other than the lack of a quick drain plug bung. Pictures show a modified suction screen plug. Can you clarify the difference?
    O-235-C1
    O-320-A series narrow deck.
    Bushcaddy's Avatar
    Jul 2009
    Marshfield, MA
    39
    Steve,
    The problem with Vans bracket and the O 235 and O 290 is not so much the oil sump but the carb. You can see in the pic you posted above the indentation in the O 235 oil sump. The O 290 is the same. This is there because the throttle arm of the MA 3 carb is "proud" of the carb and needs this indentation. The biggest isssue though is that all of Vans carb bracketts are made to fit MA 4 carbs which have a bigger opening and therefore different bolt pattern than the O 235/290. If you have enough distance between the firewall and the carb it is possible to fabricate a Vans like design brackett for the O 235 (I did this)...but found I still could not use it due to the lack of space and i ended up patterning my connections like those on a Cub. Check out this link and scroll down to Issue #3, Bill has pics and an explanation: http://www.repucci.com/bill/engine.html
    Yooper Cub rotto789's Avatar
    Mar 2009
    Mi. ( Yooper)
    194
    Clark,
    Does your Vans Bracket fit your engine? and if so do you have clearence from the fire wall? I just purchased the same bracket for mine but from what I am reading above it does not clear the fire wall, I have the 0320 B2B.
    Rick
    Clark's Avatar
    Oct 2010
    12
    Hi Rick
    Yes the Van's Bracket fits my O-360. The total length of the bracket is about 12" (see attached photo). With my setup that leaves about 2 1/2" between the end of the Bracket & the firewall. My setup is an O-360 C2A6 "Conical Mounts". Hope that helps
    Clark
Name:	Vans Bracket 12 inches.JPG
    Mar 2009
    Mi. ( Yooper)
    194
    Clark, thank you, that helps and no I don't think this will work for my configuration I only have about 9 1/2 inches center of carb intake to fire wall, on the flip side I think I will fabricate one simular to the vans bracket and use the gasket and idea from there bracket maybe even modify there's shorten it and bend it we'll see, thanks again
    Rick
    Clark's Avatar
    Oct 2010
    12
    Just wanted to update the Van's Bracket idea for the throttle & mixture cable mounting (to engine - not engine mount). I had to modify - Cut off the rear section of this bracket to clear the cabin heater box monted on my firewall (see photos attached). If anyone has any questions ask away.Click image for larger version.
Name:	Vans Bracket bottom.JPG
ID:	5553Click image for larger version.
Name:	Vans Bracket Side.jpg
    11,534
    Quote Originally Posted by Clark View Post
    very cool, no creepy throttle for you...
    someone should take the time to have these made and sell them,
    Clark's Avatar
    Oct 2010
    12
    VANs Makes These
    Hi Mike
    Van's Aircraft does make these & they are not expensive. All I did is purchase one & perfromed a 30 minuite modification of cutting off the back few inches to achieve clearance for my FWF setup.
    This info from the Van's Website;
    Van's now carries a complete line of throttle brackets with integral mixture attach points for the Lycoming O-320 and O-360 engines. These 4130 steel brackets are to be installed between the carburetor and the engine sump. This simple method only requires one additional carburetor gasket and we include it with the units listed.
    A system for installing either the throttle or mixture cable on the
    200HP-IO-360 is also available. See below.
    IT IS UP TO THE BUILDER TO DETERMINE THE SUITABILITY OF THIS ITEM TO HIS/HER INSTALLATION.
    Ordering Information
    THRTLE/MIX BRCKT IO 320/360/540 Vertical Induction
    Part Number = VA-182-PC KIT
    Price = $23.50
    Quantity
    THRTLE/MIX BRCKT/320
    Part Number = VA-149-320-PC KIT
    Price = $20.00
    Quantity
    THRTLE/MIX BRCKT/360
    Part Number = VA-149-360-PC KIT
    Price = $20.00
    Quantity
    THROTTLE/MIX KIT Horizontal Induction
    Part Number = IO-360 THROTTLE/MIX
    Price = $103.00
    Quantity
    Clark's Avatar
    Oct 2010
    12
    Im very new at these websites - here is the website link for the Van's bracket
    May 2010
    Hunt, Tx
    25
    Clark -
    I noticed that you had the bracket with both the throttle as well as the mixture cable. It appears that in order to clear your airbox you had to cut off the mixture piece of bracket......what is your plan for holding the end of the mixture sheath? I have an O360 in my PA18A with dynafocal mounts and a heck of a time holding the mixture end in the correct alignment, after 25 years of being ok, with the arm on the carb.
    Kirk Griffin
  1. Control Cables?
    By gdafoe in forum Experimental Cubs
    Last Post: 03-09-2008, 12:40 AM
  2. rudder control cables
    By pa19guy in forum Super Cub Sick Bay
    Last Post: 11-21-2003, 01:16 PM
