Aviationinfo,
The idea of carrying extra speed scares the, well you get the idea.
I like the idea of letting your buddy do the test! Works even better if you are in the back seat and walk around, then go get your plane...
BUT:
Do some passes across the sand from different directions, and different altitudes, including two feet off the ground. It may take one, it may take 8, I don't know.
How many times perfectly smooth landing areas had a great big dip or hump in the middle... light will fool you on sand! Also get distance by using the time method, (rate in feet per second at given airspeed x time in seconds- or mississippis- equals distance in feet.
Now make high speed wheels on runs to test the sand, if it bathtubs soft, (tires too much air), if it is hardly a track, firm, if the plane jumps into the air bump... you get the idea.
Do not land until you are comfortable. Again, make a few passes to get the feel for the sand, slowing down every time until it feels ok. then land and
STOP
Now get out and walk your strip and check your estimated distance with your actual usable, and find out what you did not see when looking it over from the air
. Mark any obstructions that are hard to see, (holes). Now get back in and takeoff!
The earlier thread, (forgot what it was called) talked about the ?mississippi bars all having the sand drifts one direction, so land downriver... not so up here, so I look all directions. Learning the territory is important!
Have fun!
