Likes Likes:  0
Results 1 to 18 of 18
Thread: Bungee tool in texas
    little pat's Avatar
    Port Lavaca, TX
    29
    Is there anyone in Victoria...corpus...houston...san antonio area that can replace bungees on a PA-18. I have seen a homemade tool on past supercub threads, but it seems pretty dangerous to change the bungee without the correct tool (I don't see how the homemade tool takes the old bungees off). I don't want to spend $225 on the bungee buddy, since it will only be used once every 5~10 years. Any info would help.
    Fairbanks, Alaska
    212
    Oh, it would be used a lot more than that.....as soon as your friends find out you have one!
    60below
    Clay Hammond's Avatar
    Rhinebeck NY (NY94)
    1,297
    Use an engine hoist. Totally safe. I have an old post around here somewhere detailing the op, with pictures. Just run a search for replacing bungees.
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    The safest way to do this job is to package up your Hydrasorbs and send them to Univair. They will come back pronto with new bungies installed. The bungies won't be scuffed up and there will not be even a mark on the Hydrasorb paint. The cost is reasonable especially when you consider the best part -- that you will still have all 10 fingers left (or at least the same number you had when you sent the package off). Not so much of a deal for PA-12 and some others, too expensive to mail the whole fuselage plus gear.
    Darrel
    Rhinebeck NY (NY94)
    1,297
    Our method is totally non-invasive. Why send it off for a week when you can do it literally in like a half hour?
    Here's the old thread, but the photos have been corrupted. I'll see if I can dig them up.
    http://www.supercub.org/phpbb2/viewt...ghlight=#17397
    Here's a thread where my brother recounted the procedure. Pics are still live in it. Look for his post 3-4 down.
    http://www.supercub.org/phpbb2/viewt...hlight=#172831
    Rhinebeck NY (NY94)
    1,297
    Here's the post in question, but advise reading the whole threads.
    Knock a hole in the metal channel so the strut can fit through, then slide a screw driver through the bolt hole to keep it in place. Next take a piece of scrap rope (3/8" braided seems to work best) and make a loop to catch the bungee. Start stretching the bungee using the hoist, you might find it easier if you spread the rope (black hammer in pic). Once you've got the bungee over the ears, release the hoist pressure, cut the rope and use the hoist to pull the rope free of the bungee. When you've got the strut off the airplane, use a piece of chain to hold the airplane up. Just be sure to use bolts and not drift pins.
    It's nice doing it like this because one guy can do the entire job in about an hour. There is no real grunt work; the hoist picks up the airplane while you remove the struts and insert the chain and the hoist stretches the bungee. No lever to spring back, and no screw drivers to damage the bungees. It pulls evenly on both sides of the bungee. It's safe for you, the strut, bungee and the airplane. And it only cost you a piece of rope.
    nkh
    little pat's Avatar
    Port Lavaca, TX
    29
    awesome...thanks for the pics. That actually looks easy to to do.
    aktango58's Avatar
    18AA
    9,342
    um, um,
    I might look at the Boy Scout Handbook for knots before I did this, and invest in some very quality rope...
    No insult intended, Clay, but if a deckhand used that type of lash on any of the boats I ran, he would either be on his first trip or last, maybe both
    Do not ever assume the lines will not part, and wear eye protection and hand protection!
    Rhinebeck NY (NY94)
    1,297
    There are two Eagles and a scoutmaster involved with those pictures, be careful where you're going there. The knots were fine, I think that day we used a square doubled up with two half-hitches on each side. How in the Hell you can tell that though, or the lack of, from the picture is beyond me.
    We've used this method for going on thirty years now and never had a failure.
    Where we have failed though was in the chain holding the gear together during the swap. THAT was exciting. Use quality chain as big as you can get to fit and pin it with bolts. DO NOT use drift pins. I was under it when it let go, never moved so fast in my life...
    20,158
    Re: Bungee tool in texas
    Quote Originally Posted by little pat
    Pat, You might be surprised by what one paying Super Cub.org memeber might do for another.
    Clay, Nathan looks a lot younger in those pictures.
    aktango58's Avatar
    18AA
    9,342
    Clay,
    If you say so. It does sound like the right knot, but just looks
    I usually hoist my cub for gear work. Forget the stuff under, just lift from eyes on cabin or engine mount, put a block under if you must, repair and put together.
    I never like being under anything hung or temporary... including a deer!
    Some guys have used a piece of pipe with holes drilled at each end, put it in while working on it...
    Stoddards does a good job in Anchorage on these. I do like to cut them off myself and inspect for cracks, even if I brush the paint. Cost me some repair when a crack got missed by the bungee replacement folks...
    WindOnHisNose's Avatar
    Lino Lakes MN (MY18)
    4,396
    Any updates/tips for removal and install of bungees on a hydrosorb? I have run out of time to send them to Steve Pierce and Univair. Wayne Meier is willing to help me with these using the technique mentioned in this thread (I think). Any suggestions would be very welcome!
    Randy
    Larry G's Avatar
    Nov 2010
    Minocqua WI
    281
    Randy try Jay at Javeron you must only about 1 1/2 hours or so away
    Larry Experimental Supercub PA18 wide body
    http://www.mykitlog.com/Supercub
    I'm positive there is no life on other planets - if there where, America would be sending them financial aid
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    354
    I tried the above method Randy. Frightened myself whitless. The box steel, holding the bottom of the hydrosorb, I thought was plenty solid enough. But there is so much force it bent it. My next move was to pack the whole lot up and send them to the man.
    Next time I'm going to go for the ASOS gear. Expensive I know but it shows you how much of scare it gave me when that steel box section bent.
    If your just changing them because they're due, I'd suggest go on your trip and worry about them when you return.
    Also reading above re the chain being used as a temporary link in the gear, I've got Atlee Dodge sea plane lifting hooks. I wouldn't work on the gear without them. Fantastic things. I've posted, as others have a few photo's of them in use other threads here before.
    Enjoy your trip.
    C130jake's Avatar
    Sep 2012
    Minnesota
    412
    Randy, the guys at Stanton have a bungee tool they let me use building my carboncub. They all left the hangar and went to lunch while I installed mine. AOSS next time they are due for me.
    Jake
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    15,239
    Doesn't the engine hoist cost more than a bungee tool?
    Rhinebeck NY (NY94)
    1,297
    Everyone has an engine hoist available to them with just a little asking somewhere within a half mile of any hangar. If a little common sense is used, with a healthy respect for stored energy and proper support materials, it is a simple and painless way to do a bungee change without specialty tools and without danger of bodily harm. I can't believe after all these years folks still bitch and fuss about the idea. Simple and proven.
    4,396
    Took heed of the warnings, Dean Nordswig contacted me about a fellow 5 miles from KANE (Surfside) that does this task. Grant Wallace provided the contact info. Easy solution.
    SJ, the fact that the engine lift is more expensive than the tool is irrelevant
    Thanks for all the advise, fellas!
    Randy
  1. Bungee tool
    By Longwinglover in forum Tips and Tricks
    Last Post: 08-17-2006, 08:48 PM
  2. PA-12 Bungee Tool
    By PA-12 Super Cruiser in forum Super Cub Sick Bay
    Last Post: 12-31-2003, 10:16 AM
