Results 1 to 2 of 2
Thread: Radio/transponder suggestions
    Oct 2008
    Timaru South Canterbury New Zealand
    3
    I have to replace the ancient mode c transponder in my cub.
    Rather than buy a new model and stack it on top of an ancient radio (that still works).
    I wonder if the wise and cunning out there, have any suggestions for a transponder/720channel radio combo ( I am not rich) that is type approved for mounting in a cub and is small enough not to clutter an otherwise tight space. My cub has the original 1957 instrument panel.
    My currently situation is both are mounted (more like slung) up under the instrument panel. I have the normal space in the port (L) wing root, but are unsure if there is a recommendation that would even fit in there.
    Any suggestions apart from the obvious gratefully received..
    Cheers and thanks...
    Sep 2006
    520
    I think Becker makes one that will fit the standard instrument hole, they also make a radio that fits the hole too.
    http://www.airplanegear.com/becker.htm
  1. Radio/transponder suggestions
    By Kiwisupercub in forum Tips and Tricks
    Last Post: 11-26-2008, 01:23 AM
  2. Radio and Transponder needed in Houston area...
    By Sam Beckett in forum Cafe Supercub
    Last Post: 02-03-2004, 03:06 PM
