Results 1 to 10 of 10
Thread: Wood Prop info/advice for 160 hp O-320 B2B
    Sep 2004
    Illinois & Wisconsin
    665
    Would anyone with knowledge or experience in wood prop options for a O-320 B2B care to comment on the best wood prop setup for a flatlander on seasonal wheelskis and floats. Get up and go is somewhat important but not as critical as with supercub strips and high density altitude. I've run a Borer with a 43 pitch which worked great, but most of the time I wished I had better cruise performance at the cost of slightly less takeoff performance.
    It's for a PA-12. Certification is a plus but not required.
    Tim's Avatar
    Petersburgh, NY
    3,507
    I have a narrow deck 0-320, 160hp in my 2+2 and really like my Sen. 80X44 wood prop.
    wheat's Avatar
    Jan 2005
    115
    Hi,
    Jim Drometer is the wood prop guru, especially on the Pa-12. His contact info used to be drometer@aol.com or 800-325-5474. He sells the props and also has extensively tested all of them.
    Sep 2004
    665
    How much did it cost and what does it weigh? Do you have any metal prop comparisons regarding performance?
    wheat's Avatar
    Jan 2005
    115
    BTW, Drometer is in Wisconsin.
    Jim
    nd
    3,493
    Correct me if im wrong, but Jim lives near BellePlaine, Minnesota.
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,946
    For a given RPM the 80x44 Sens. would probably cruise about 8mph faster and would indeed cost you some takeoff and climb performance. It weighs 18 lbs.
    Tim's Avatar
    Petersburgh, NY
    3,507
    Perry, on my plane, the 80x44 decreased my ground roll on take off about 75ft compared to my wood 74x56 and decreased my cruise speed about 8mph
    wheat's Avatar
    Jan 2005
    115
    Tempdoug,
    You are so correct....my apologies.
    Jim
    WWhunter's Avatar
    Aug 2003
    1,472
    There are a couple of guys on this site that discussed using wood props albiet on Super Cubs.
    I think one of them was JMBreitinger and possibly Sam Beckett discussed using a wood prop when he had his SC.
  1. Advice on buying wood spar J3
    By a3holerman in forum Cafe Supercub
    Last Post: 09-23-2006, 04:44 PM
  2. Replies: 5
    Last Post: 06-12-2005, 11:10 PM
