Results 1 to 15 of 15
Thread: Wing Root Fairing Rubber Seal : Replacement
    Jul 2003
    Seattle, WA
    9
    I got new wing root fairings from Univair a few years ago. They were obvious military surplus of a certain age, and now the rubber extrusion has lost flexibility is starting to crack.
    Looking at the Piper drawing 12276, it is Miami Rubber Co. Rubber extrusion 1-796A, held on with Bostich rust resistant staples type SCCR 25 3/8.
    I did a cursory look thru Univair catalog but no joy.
    Any Cub Drivers out there know a source for the rubber extru and the staples ? Any alternate ideas for fastening the extru to the fairings instead of the staples - bonding ?
    Thanks as always- Whitecub
    Ursa Major's Avatar
    Oct 2002
    Coeur d'Alene, Idaho
    1,078
    I bought the rubber extrusions from Stoddard's in Anchorage. Instead of the staples just use safety wire and make the twist on the inside of the fairing.
    N5126H's Avatar
    Anchorage, Alaska
    630
    I used safety wire and stitched the whole thing without twisting behind each pair of holes. Looked good too
    21,891
    I buy the rubber from Univair and A/C Spruce and use 3M weatherstrip adhesive to hold it on.
    NimpoCub's Avatar
    May 2006
    3,024
    Bought mine this spring from Univair & the rubber was stapled on the aluminum already.
    Jul 2003
    Seattle, WA
    9
    Ursa & N51, thanks very much for the info.
    Steve: In Spruce catalog, which rubber extru p/n do you recommend ?
    Nimpo: I'm looking to replace the seal, not the whole fairing !!
    thanks from Whitecub
    behindpropellers's Avatar
    NE Ohio
    7,043
    Quote Originally Posted by WhiteCub
    I think I have seen this extrusion in the Wag Aero Junk catalog also. Might be a safe thing to buy from them since they probably do not make it.
    Tango Cub's Avatar
    Sep 2005
    Duluth MN
    140
    Quote Originally Posted by WhiteCub View Post
    Which rubber extrusion seal do you order for front windshield fairing do you order from Spruce catalog there are 4 different P/Ns for the almost the same seals?
    Life is not measured by the number of breaths you take but by the times that take your breath away
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    895
    P/N 05-01300 or 05-01400
    21,891
    Univair sells the stuff that Piper used. I install it with 3M weatherstrip adhesive. I hate those staples Piper used. It is like the one posted on the left above. Can't find the interactive parts catalog on Univair's website now.
    Apr 2017
    36
    I have a -12 with the square top windscreen. How well would the -18 Univair wing root fairings fit on my -12? Anyone know?
    -Chris
    RaisedByWolves's Avatar
    Feb 2005
    4,711
    Quote Originally Posted by Bearhawk Builder View Post
    Where’d you get it from?
    I got some from Univair but it lasted a couple years and cracked pretty bad.
    Aug 2012
    In the woods
    895
    Those are spruce numbers. I have a mile long roll of the smaller stuff if you need some
    21,891
    I have used U19657-000 from Univair which is right out of the Piper parts catalog on every Super Cub I have rebuilt and lots of others I have repaired with no known issues. https://www.univair.com/piper/piper-...moulding-2-ft/
    nanook's Avatar
    Aug 2002
    northern alaska
    1,759
  1. lower wing root fairing
    By Rob Murray in forum Experimental Cubs
    Last Post: 05-27-2009, 10:36 AM
  2. wing root fairing
    By DW in forum Cafe Supercub
    Last Post: 11-30-2007, 12:43 AM
