Results 1 to 7 of 7
Thread: mag problem
    Apr 2005
    Wasilla AK
    29
    mag problem
    During my run up yesterday I noticed no drop in rpm on the left mag. The right showed normal drop. I turned to off and rpm remained the same as on right mag only. Any suggestions for me while I try contacting my mechanic?
    Ken
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,051
    Sounds like P lead might be broken. If so, you have a hot mag.
    DW's Avatar
    Dec 2002
    pacific northwest
    2,067
    Definitely sounds like a hot mag and a bad P lead be careful around that prop till you get it fixed.
    fadec's Avatar
    Oct 2007
    Mooresville, NC
    154
    Please be careful.
    These guys are spot on... We just had a guy that scraped his ear (mildly put) and has an extremely sore shoulder. luckily he was 6'5". Live mag, found a broken p-lead at the mag connector, it looked good but.... Ive seen switches that were messed up too, hence the AD 76-07-12. Treat that prop as it is HOT
    Take the leads off of your spark plugs and do a simple continuity check on your p-leads. You'll find the problem.
    Apr 2005
    Wasilla AK
    29
    Thanks for the feedback. The hot prop was my first concern.
    Steve's Aircraft (Steve)'s Avatar
    Aug 2002
    White City Oregon
    233
    Consider that prop hot "ALL" the time. In the forty years I have been working on them I have had three of them take off when they where not supposed to. One bad P lead, two switches bad. The only time I feel somewhat safe is when "ALL" the sparkplug leads are out. I consider them the same as firing pins in my guns.
    Steve
    Apr 2005
    Wasilla AK
    29
    Found it, simple fix.
    K
  1. ptt/elt problem
    By bmc1818 in forum Cafe Supercub
    Last Post: 04-22-2007, 12:01 PM
  2. Spray Gun Problem.
    By CaptFox in forum Tips and Tricks
    Last Post: 12-06-2006, 07:33 AM
  3. Transponder Problem
    By Matt 7GCBC in forum Super Cub Sick Bay
    Last Post: 04-20-2004, 10:47 PM
