AntiCub
North Pole
oldbaldguy said:Noted several times during preflights that the belly seams of my C-model 182 were wet. It was parked outside and I thought maybe rain water was getting in, so I took my dad's old hirdy girdy drill and drilled a small hole in at the lowest point. Several gallons of water drained out all over the ramp. Seemed like it took forever. No telling how long it had been trapped in there.
My 150 leaks somewhere and after a rain I have to push the tail down and wait a couple minutes as all the drains at each bulkhead run for a couple minutes. A 150's performance is anemic enough as is, without an extra 50 lbs of water in her belly.
Scariest thing ever found at annual was a badly corroded spar slice angle. The rivet tails popped off when the mechanic brushed them with his fingers. See pictures here: http://www.mosquitonet.com/~wanderer/Aircraft/corrosion.htm
Both wings have been completely rebuilt and epoxy coated inside now.
Phil
