KJC
Clear Lake, MN
I am in the process of rebuilding the wings on my -12 which has Ferguson Wing Boosters STC SW 573 SA. When I took everything apart, nothing was really square on the trailing edge from the aileron out to the tip. The wood piece that is the trailing edge outboard of the aileron wasn't square with the tip and the aileron. Also, the wood but rib doesn't seem to be long enough to square it with the new Dakota Cub ribs. The whole thing was kind mickey moused in there when I took it apart and I won't put it back that way.
1. Does anyone have any first had experience with installing Ferguson Wing Boosters?
2. I assume the trailing edge of the wing from the butt rib, flaps, aileron and wing tip should be a perfectly straight line. Am I correct in this assumption or should the trailing edge from the aileron out to the tip be at at a slight angle like they were when I disassembled them?
3. Cub Crafters ownes the STC now and Vera was nice enough to send me the instructions (thanks again) but they are old and hand drawn and don't mention modifying the aileron to square it up on everything. I want to verify the mech who did the install in 1967 did it correctly before I recover them. Anyone ever seen the drawings or instructions or did they just match them to the tips?
This STC is pretty old and is generic to the -11 -12 -14 -20 and -22. The spars have been modified and I don't want to start with something new (money is a big factor).
Any thoughts are appreciated.
Kevin
Kevin
