Thanks Thanks:  0
Likes Likes:  0
Results 1 to 16 of 16
Thread: Wheel pant brackets for PA-12
    Circle Pines MN, north of St Paul
    89
    Hi, I'm trying to get some information for a friend that has a PA-12 and wants to mount some Consolidair model 17 wheel pants. He has stock 800 x 4 Cub wheels and needs a drawing or some where to get the brackets, if someone sells them. I just looked at them and they have 4 dzus fasteners on them for mounting. I would appreciate it if someone could point me in the right direction to help him out. I don't know a lot about Cubs as I'm a Champ driver myself. You guys have a great web site and I try to check it out whenever I can. Thank you, Jim
    moneyburner's Avatar
    Mar 2003
    Western Washington
    986
    I dunno, Jim - we generally run around here without any pants.
    (Couldn't resist!)
    Mar 2007
    518
    HAHAHAHAHAHAHA!!!! There was a 12 at S&F with pants, so I know it can be done. Looked pretty good, actually.
    White City, Oregon
    920
    Do they look anything like the mains on the early tri-pacers....like this one?
    If so, I have a set in a box to ship out that have the brackets. I can take the brackets out real quick and snap a couple of photos.
    Brian.
    89
    They look similar, but I think they are a couple of inches longer. He has a nice custom Super Cruiser and I think these old style pants clash with the plane, but it's his plane. Personally I think they are just big air scoops. But I don't know what else would fit on stock wheels. Jim
    d.grimm's Avatar
    Oct 2004
    toledo, oh
    473
    Jim,
    There is a set like these on a original Pacer that I fly. It's not real accessible right now for a picture. Try www.shortwingpipers.org. They will probably get you what you need.
    Dave
    White City, Oregon
    920
    Yep, the early aluminum version of the same ones used on early Pacers / Tri Pacers.
    Backplate looks like this.
    As you can see, they are dead simple. Flat plate with a simple clamp arrangement around the gear leg.
    To make it even more simple, I made a quick outline on a piece of cardboard for you, shoot me a address or give me a call at 541-826-9729 and I will get it mailed out to you.
    Brian.
    89
    Thanks Steve, I thought someone on this site would know something about these brackets. Please send a couple of dimensions like thickness and size of bolts also. Send to Jim Gevay 9 Oak Rd. Circle Pines MN 55014. You Super Cub guys are pretty cool! Thanks again, and is there anything I can do for you? Jim
    White City, Oregon
    920
    Jim,
    They look to be about .062 steel. 3/16 (AN-3) bolts.
    I would use the pattern to make a blank and then cut and fit to the
    pants and airplane. Will probably need to R&R them several times until you get it right. Look at the pics while you are doing them, I will leave them in my gallery and I printed them out on one sheet of paper for your reference.
    Next time you or your buddy has a problem with your or his gascolator, give us a ring.
    Brian.
    89
    Sorry, I didn't realize your the guy with the gascolators. I've seen some pictures, they look very nice . Thank you! Jim
    Apr 2007
    Kingsburg, CA
    1,256
    Quote Originally Posted by Steve's Aircraft (Brian) View Post
    Brian.
    Brian,
    Is the bracket that goes around the axle just edge welded to the plate? Do you have a better picture of this area?
    Apr 2007
    Kingsburg, CA
    1,256
    I just got home from the airport looking over my plane. I don't see how these original PA-12/early tripacer backing plates will work. I have double puck Clevelands. Because of the rotor, the backing plate will not be able to go straight down to the axle clamp. Also, I can only mount the caliper on the front side of the wheel. On the back side, the caliper will hit the gear. My torque plates only have 4 holes, allowing the caliper to either be mounted on the front or the rear of the wheel.
    I know most guys don't run wheel pants on their Cub but is there anybody out there who has them on their plane and if so, how are they mounted with Cleveland wheels and brakes?
    May 2002
    Cranbrook,B.C.
    242
    Fender brackets
    My J-5 piper with Consolidaire model 17 wheel fenders installed.
    Not sure that this is the original mounting brackets for a cub.
    Aurele
ID:	31159   Click image for larger version.
ID:	31160   Click image for larger version.
    evroosevelt's Avatar
    Dec 2009
    Wilsonville, AL
    159
    I have 2 sets of PA-12 wheel pants each set with different mounting brackets I will send some pictures of both tomorrow.
    EV
    3,153
    I believe the proper term is "wheel panties".
    Dec 2009
    Wilsonville, AL
    159
    Jim can you send me your email address I will send the pictures unable to post them here?
    EV evroosevelt@hughes.net
  1. PA12 wheel pant mounting brackets
    By FirstCruiser in forum Experimental Cubs
    Last Post: 04-29-2007, 08:10 AM
  2. Wheel Pant Attach Drawing?
    By klm_ak in forum Modifications
    Last Post: 06-22-2003, 01:29 AM
