My hard staring 0-320 problem might be solved. Guessing here and would like any help. Reading back on some of the past posted ideas some one suggested the impulse coupler. I had thought that the impulse coupler would be good because when I pull the engine through by hand I could here the coupler snap. So I thought it would not be the problem, but... When I first attempt to start my engine it has a fast rotation, (hot battery) but does not fire up. After the battery gets low and after I have messed with the starting for 30 minutes letting the starter cool down between starts and by then the ENGINE WILL STILL TURN... BUT VERY SLOWLY that's when the engine starts. Just like you have turned on the ignition. I think that the impulse coupler is worn and when the engine is cranking fast the couple can not engage so it can't wind up and produce the spark I need. I will know for sure when my mechanic pulls the mags (slicks) Anyone been through this? thanks teeweed
