Results 1 to 10 of 10
Thread: Remavable Rear Seat Crossbar and Pilot Seat Belt Attach
    18,654
    My welder friend is here and I am running out of work for him so I got my L18C frame out of the storage hanger and into Scot Warren's jig. Got my angle of incidence nailed down, a dented tube replaced, X-brace going in now and was planning on installing the removable rear seat crossbar and weld-on pilot seat belt attach. I tried to call Steve at Atlee's but they aren't there yet. Does anyone know if they sell the STC without the parts? I would like to buy the STCs and cut the tubing myself. I have the tubing and plate and time is of the essence. I love it when I can get some of my own projects done.
    Anything I am missing on a light weight 90hp Super Cub that should be welded into the fuselage?
    behindpropellers's Avatar
    NE Ohio
    6,692
    They sold me all of the STCs without parts.
    Aug 2002
    AK
    258
    Don't forget the bushing for the tailspring bolt, I always bush for a -7. A -6 would work fine for 90hp. Rear shoulder harness - 3/4" .049, 9" forward of the cathedral cluster. Check all gear fittings, wing/strut attach, and fwd trim pully for slop and rebush as needed. Lifting handel on the LH side and three foot metal belly.
    Jerry Gaston's Avatar
    Nov 2002
    Bozeman, Montana
    1,388
    Yep a gun rack!
    Nov 2002
    Charlotte, NC
    1,859
    Lower tail wire attach points - convert to strap?
    John Scott
    Jan 2005
    wasilla ak.
    342
    instead of making the the crossbar removable i have seen where it swings forward and pins in. It also can be removed. This is a nice mod if you haul stuff and are always removing crossbar to load. I am sure someone has a picture on this site. not sure of the legality of it but it is very common up here in the north country.
    18,654
    Well I talked to Steve at 7:35 am AK Time and ended up buying the X brace STC $50, the removable rear seat tube $145 and the front seat belt floor attach STC kit $75 vs. $50 for the paperwork. After going to the big city last weekend and dropping big bucks to outfit all the kids in shoes and a good sit down meal it was time to spurge on the Super Cub a bit.
    Don, Thanks. Forgot about the rear shoulder harness attach and gotta check for slop. Haven't decided on the 3' of metal belly.
    John, Why the strap? I knew they had a problem when they were TIG welded.
    Nov 2002
    Charlotte, NC
    1,859
    Quote Originally Posted by Steve Pierce
    Steve,
    I was going off memory (which is slowly failing ) and thought there was a SB for this... Maybe I'm wrong?
    Found this thread by search: http://www.supercub.org/phpbb2/viewt...il+wire+attach
    John Scott
    Akureyri
    252
    John,
    Piper SB 706A covers the tail brace wire support installation.
    18,654
    OK, another project. I know there is a tube added to the PA18-95 (L18C) and others for a gross weight increase or to add the O-320 up front. Is it the part number 11857-99 1/2" tube that goes just behind the stock battery box to the bottom longeron cluster at the elevator pulley bracket behind the stock baggage? I notice the Northland Drawing shows tubes between all those clusters but somewhere I saw this tube on a stock frame.
  1. Rear seat belt STC? Yes or No?
    By BritishCubBloke in forum Modifications
    Last Post: 05-06-2004, 04:43 PM
  2. Replies: 13
    Last Post: 06-02-2003, 06:10 AM
