Results 1 to 11 of 11
Thread: Nose Seal
    Nathan K. Hammond's Avatar
    Nov 2002
    Danville, KY DVK
    477
    Nose Seal
    Apparently Nose Seals and my family don't play well together. Both me and Dad have tried to seal up the nose on our O-300 and C-85, but can't stop the oil from coming out. We did the service letter on the O-300 about scoring grooves and that didn't help. We've also clipped the springs a little and that didn't help.
    What's the trick to getting a real good seal on a Nose Seal?
    nkh
    jgerard's Avatar
    Nov 2004
    Seattle, WA
    894
    Are you greasing the lip of the seal before you install it? If not you run the risk of burning it from the friction which can cause it to leak.
    Jason
    Janesville,WI
    309
    Continental didn't have much luck getting them to seal either. Someplace there is an old service bulletin about gluing a felt ring on the outside of the seal to soak up the oil on the O-300's. Rotten Continentals I think their like radials if their not leaking oil there's no oil in them.
    Matt
    19,801
    Dang Nathan, I know how you feel. Fortunately I have always been able to fix them with the crosshatch.
    behindpropellers's Avatar
    NE Ohio
    6,801
    Jeff Russell is the master of nose seals.....he will chime in here, I think he changes his once a week!
    N.W. Iowa
    90
    Try using distributor cam lube grease on the sealing lip, Bosch brand seamed to work the best.
    Dennis
    NC
    1,048
    Just call me, "Lucky"....
    I reckon I'm just lucky. I've had several continentals, including a C-145, and none of them leaked at the nose seal. I flew that old C-170B over 1000 hours, and not a drop??? My wife's Champ has a C-85, and it doesn't leak. I wouldn't call "Continentals" a rotten engine either since they don't have the AD's Lycoming engines have.
    Mike
    JP's Avatar
    Mar 2003
    The Big Woods of Maine
    3,228
    Quote Originally Posted by behindpropellers
    Don't even get me started....
    JP Russell--The Cub Therapist
    1947 PA-11 Cub Special
    www.bloomerrussellbeaupain.com
    Nov 2002
    Danville, KY DVK
    477
    Thanks guys. Jason, I think you hit it. We'll find out Saturday or Sunday.
    nkh
    Flying Miss Daisy's Avatar
    Jun 2004
    Wentworth NH" The WAD" NH96
    3,304
    Jeff,
    Bosch lube grease who knew!!!!!
    John
    citabrickr
    Guest
    Quote Originally Posted by Flying Miss Daisy
    Jeff,
    John
    Actually most engine manuals explicitly say to not use grease, just a very little bit of oil so the seal can break in correctly. Trying to prevent wear by greasing the crank will cause the seal to never break in and it will always leak.
  1. 0-320 Nose Seal
    By behindpropellers in forum Super Cub Sick Bay
    Last Post: 09-01-2010, 10:07 PM
  2. 0-320 nose seal
    By aggieflyboy09 in forum Cafe Supercub
    Last Post: 09-24-2008, 01:46 AM
  3. nose seal
    By JMBreitinger in forum Cafe Supercub
    Last Post: 04-03-2007, 06:30 AM
