Thanks Thanks:  0
Likes Likes:  0
Results 1 to 12 of 12
Thread: stall device
    Tim's Avatar
    Feb 2002
    Petersburgh, NY
    3,506
    stall device
    For some reason I just thought about this. On the way home from Hew Holstien this year I stopped for gas I think in Illinois somewhere. There was a guy there with an old Supercub getting gas. He used the plane for banner towing and I was just looking it over. Underneath the trailing edge of the wing was a piece of angle aluminum running the length of the wing. I think it was about 1/4 inch angle. The guy said it lowered his stall speed. I've never seen anything like it before. Anyone ever seen this or know anything about it.
    Tim
    Nathan K. Hammond's Avatar
    Nov 2002
    Danville, KY DVK
    477
    Sometimes called a Gurney Flap; they had REALLY good results with them on race cars. I've heard they can do wonders for an airplane.
    http://www.allamericanracers.com/gurney_flap.html
    nkh
    Sep 2002
    1,621
    Gurney flaps can give about a 10 to 15 percent boost in lift without much of a drag penalty. Typically, they are about 0.75 to 1.5 percent of the chord. For a Cub, I'd expect them to protrude about 5/8 to 3/4 of an inch (1/4 inch sounds skimpy).
    JimC
    KelvinG's Avatar
    Jan 2004
    Talkeetna, AK
    214
    Would anyone have a few pictures showing a typical installation? Would light gauge 3/4" aluminum angle work?
    KelvinG
    Jun 2005
    Texas
    444
    Stall Device
    When Cessna certified the stretched Caravan (208B Grand Caravan) they added a gurney strip on the trailing edge of the flap to keep the stall speed down with the new higher gross weight. It is a fairly simple attachment.
    Tim's Avatar
    Feb 2002
    Petersburgh, NY
    3,506
    I would love to try it, but can't figure how to attach them without screwing up the trailing edge in case I want to take them off.
    Tim
    behindpropellers's Avatar
    Feb 2003
    NE Ohio
    6,781
    Call 3M I'm sure they have some double stick tape that will work. The only problem...is when you want to take it off. I can show you some velcroe like stuff that will work if you want.
    Tim
    Mikey's Avatar
    Everett, WA
    518
    Is the famed 'bird strike deflector' on the trailing edge of the original Citation rudder a double Gurney?
    Tim's Avatar
    Feb 2002
    Petersburgh, NY
    3,506
    If this was on a supercub, there must be an STC somewhere, Anyone know who has it. That might shed some more light on things.
    Tim
    Sep 2002
    1,621
    >Is the famed 'bird strike deflector' on the trailing edge of the original Citation rudder a double Gurney?<
    No. Gurney's by definition go only on one side ot the trailing edge. As an aside, Gurney's were originally called Wickerbills till Dan Gurney made 'em famous on race cars about 20 or 30 years ago. They've been known for most of a century now.
    I don't think there are any STC's for their installation on a Cub yet. The easiest way to install them is with rivnuts. Cut small individual circular holes in the fabric along the trailing edge that just fit the 'head' of the installed rivnut so that it minimises the protrusion and then mount the Wickerbills on that. The rivnuts aren't noticable when the Wickerbills are removed (particularly if painted to match the fabric), and Wickerbills can be removed and reinstalled in three or four minutes.
    JimC
    Nov 2002
    33
    I don't want them falling off. Would sheet metal screws work? Or is there a way to just use a length of Gorilla tape from the top to bottom while trapping a rectangular section to the bottom trailing edge?
    Don't need them looking too obvious either---
    So did anyone find an STC?
    Sep 2002
    1,621
    I would recommend against sheet metal screws. Rivnuts would work.
    JimC
  1. Stall Horn to Stall Light
    By banner tow pilot in forum Take Action Jackson
    Last Post: 11-25-2008, 11:45 PM
  2. New device from Garmin when?
    By Rookie in forum Cafe Supercub
    Last Post: 12-12-2003, 05:21 PM
