Results 1 to 15 of 15
Thread: Lightspeed Ignition
    Feb 2007
    Arizona, Alaska, S. America, Africa, Iraq, Afghanistan, Various
    117
    Lightspeed Ignition
    Gang,
    I've perused the archives for information on electronic ignition, but I haven't found what I'm looking for.
    Is anyone out there using Lightspeed Engineering's electronic ignition?
    Thanks.
    Tom
    N370GL's Avatar
    Oct 2005
    NJ & MT
    45
    I'm using it...it is awesome.
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,501
    What all do you like about it, 9lp?
    Feb 2007
    117
    An actual user! Great!
    Could you give me a run down on any differences in your fuel consumption, performance, and condition of your spark plugs you've noted, if any?
    Also, did you get a field approval or are you experimental?
    Thanks.
    Tom
    Jan 2005
    Fowler, Ks
    636
    My RV6 originally had a lightspeed ignition, it is sitting in a box in my hangar right now.
    I was having some intermittant trouble with it and my FBO took it off and replaced it with a mag. I think the only trouble with it was a loose wire. I liked it. It was the type of electronic ignition that sensed off the flywheel.
    It would produce noticably more power. I don't have any numbers but the engine ran stronger and smoother on the electronic side than the mag side.
    kase's Avatar
    1,582
    Works great.
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    Kase,
    Which Lightspeed do you have? I was trying to build an engine on Superior site and all the choices are confusing. Plasma II+, III, hall, crank, etc.
    Feb 2007
    117
    Kase, 9lp, any other users,
    Some questions for you:
    What are the pros you've noted?
    Any cons to go with the pros?
    Did your fuel consumption go down any?
    If so, approximately how much?
    Do your plugs stay cleaner/foul less?
    Did you notice any increase in performance?
    Anyone out there have a 337 example (precedence) for installation in a certified engine?
    Thanks.
    Tom
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    Klaus at Lightspeed does a first class job on anything he does. His ignition is great, really helps the performance. Also if you want to get someone to port and polish your cylinders, balance the rods, and make you some forged high compression pistons, you can't go wrong.
    KelvinG's Avatar
    Jan 2004
    Talkeetna, AK
    214
    Tom,
    I assume you've seen the CAFE reports, ( 1, 2, & 3) on electronic ignitions. I can not give you a before and after because it's going on an expermintal I am building. I can tell you that the workmanship looks great and Klaus was very helpfull.
    KelvinG
    Jun 2007
    Ogden, Utah
    5
    Quote Originally Posted by Check Six
    Thanks.
    Tom
    Yes, a 10% fuel burn improvement at altitude and it starts more like a car, "right now," No cranking. The 10% improvement comes mostly from timing advance for altitude, mags cant do that. I would never go back to all mags. Have Lyc IO360C1D6 245 HP 10:1 compression modified crank larger intakes flowed and ported. Stock was 200 HP angle valve 4 cylinder. The 10% fuel burn improvement is the real deal.
    All positives, no negs. Plasma III, starter ring gear pickups.
    7,405
    Is it STCd on the big Lycoming?
    Jun 2007
    Ogden, Utah
    5
    Quote Originally Posted by bob turner
    Possibly, but mine is experimental with 3 blade CS prop (composite with wood core).
    Feb 2007
    117
    KelvinG,
    Yes, I've read the CAFE reports but they didn't contain the info I was hoping to find. Thanks for the reference. Hope you get yours flying soon!
    XeVision,
    Big thanks! That's falling right in line with the feedback I'm getting from other actual users. A 10% to 15% decrease in fuel consumption seems to be the average. The only cons seem to be cost (which is slight when a mag purchase or overhaul is factored in), installation, and needing to get approval for certified engines.
    Looks like E.I. is a real winner!
    Tom
    7,405
    I checked their website. No FAA approvals, and they are still waiting for somebody to get a field approval.
    Ought to be easy to get approval for one Lightspeed and one certified mag - but the feds don't care about advancing the art, I guess. Boo!
  1. lightspeed ignition
    By buckeye in forum Modifications
    Last Post: 09-30-2010, 02:03 PM
  2. Lightspeed Ignition?
    By ksecub in forum Experimental Cubs
    Last Post: 12-11-2005, 12:42 PM
