a3holerman
Cape Cod
Hi,
Have been in the process of overhauling a C90-8 for my 46 J3 along with my A/I. The engine on the cub now is a 65 that along with the help of many here we overhauled the Stromberg carb and it runs great now. Made the float level adj. tool and setup bench to test it. Worked out great and was a good learning experience. I have just taken apart the C90 carb and found the needle was a neoprene type with very neatly inscribed numbers....not good as I understand it. I do have the new delrin needle on hand and will have to use it.
Two questions if I may. First ,the main appears to be a #49 and the air bleed I cannot see any markings. I have the overhaul manual manual and it seems to call for a #46/#60 combo. I am getting a set of numbered drills this afternoon and will confirm the sizes. Can one drill out the 49 to a 46 and have it function properly?
The second question concerns the installation of the delrin needle. The instructions call for a counterweight made form 3/32 brass stock. I have checked everywhere I can think of and have not come up with this size stock. Has anyone done this mod and where did you find the stock?
Thanks in advance for any help.......
