Page 1 of 2 12 LastLast
Results 1 to 40 of 45
Thread: installing flaps on a PA-18 95
    Apr 2007
    8
    I'm sure it has been discussed, but has anyone installed flaps on a PA-18 95? If so, was it worth it and what did it cost? Was it hard? Would you do it again? Any info would be appreciated.
    Clearwater,Fl
    2,585
    It will require welding in pulley brackets, flap handle brackets, and then installing all the parts for the wings. I would suggest you look at uncovered wing and take lots of pictures. Its a pretty big job but only should be considered if you are recovering your entire airplane. I'd locate the parts before tackling that job. And you should have a professional welder on hand. I just completed the fuselage part of the conversion. It will make your airplane more desirable upon resale but don't know if its worth it from a flying perspective. If you don't need the extra performance I wouldn't do it. Buy one already with flaps. My 12 doesn't have flaps and I don't' need them.
    behindpropellers's Avatar
    NE Ohio
    6,919
    Kase has some information on doing it.
    My vote is to keep it light.
    jnorris's Avatar
    Wisconsin
    881
    Don't do it!!!!
    Joe
    Fortis Fortuna Adiuvat
    Apr 2007
    8
    The pulley brackets are all there, as is the flap handle mount. This plane could have gone either way out of the factory. Right now it is in near showroom condition so a recover is out of the question. I am looking for someone who has actually installed flaps on a PA-18 95, I know you guys know your stuff but it doesn't sound like you have actually done this exact mod. Anyone out there that has done it on a flying aircraft?
    Thanks flyboyrv3 thanked for this post
    NE Ohio
    6,919
    Quote Originally Posted by flynfishr
    You would need a new seat base too, if it does not have the bracket on it.
    Apr 2007
    8
    As I said, the bracket is there.
    7,441
    The world is full of big Cubs with flaps. It is not full of 90HP lightweights. Sell it, and get what you want. When you are going ten mph faster and burning twice as much gas, you will remember your 90 fondly.
    jnorris's Avatar
    Wisconsin
    881
    Quote Originally Posted by bob turner
    Amen, Brother Bob. I couldn't have said it better myself.
    Joe
    Feb 2004
    Mt.
    1,341
    flaps
    As I understand it ALL pa-18 airplanes had all the provisions for flaps when they left the factory so it would just be a matter of modifying the wing for the flaps then installing the pulleys,cables and flap handle. If it was mine and I was going to keep it I would do it in a second as it adds to the fly-ability of the plane. Wayne Mackey has done this mod several times, you could call him at 406-951-3935 he could tell you what is involved.
    Dave
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,428
    You probably have a later year 18-95 which actually has the same fuselage as the 18-150, so adding flaps would be a bolt in installation in the fuselage. The wings would need some major work to install the trailing edges and hangers, this would best be done at wing recover. Also, if you still have the stock tail, you would also have to switch to the balanced tail feathers. I've never flown a 18-95 with flaps, but every 18-95 I've flown I really missed having flaps, so I would definitely add them if it was possible.
    Apr 2007
    8
    I already have balanced tail feathers. I was really hoping it could be done without recovering the wings, they only have 150 hrs since new. I will talk to some local shops here in Alaska and see if I can find a fabric artist. Thanks for the info and phone numbers. I will post when I get moving on it.
    agavmechanic's Avatar
    Butte Valley, California
    37
    For what it's worth, I also have a pa-18 that used to have a 95 in it but was upgraded with a borer stc and currently has an 0-320. But no flaps. I did some digging, and to put them on, some Ia's tell you it's just a log book entry with the drawing, and some tell you it's a major alteration hence needing a 337. I looked up the type certificate data sheet, and depending on what serial no. yours is, there was two drawings for flap installation. I finally obtained the drawing I need for mine. Drawing no. 13766. Next for me, is to obtain the parts. If you need any more help, as far as getting the drawing you need, let me know. Good Luck.
    Bill Ingerson's Avatar
    Jan 2004
    Snohomish Washington
    1,433
    Flaps
    I have a project I'm working on, a PA-18 105 special that came with no flaps or brackets. I bought all the weld fittings and welded them on using a gas welder. Then we found some pacer flaps and lengthened them to the right length. All this work was done by a experienced cub builder and will work just fine. You will need to get into your wings alright and recover when done.
    Go see Dan at Dans Aircraft in Anchorage, they recover and can do everything you need done.
    Just my two cents, you will pick up some weight, but for me its going to be worth it.
    Wayne Mackey's Avatar
    Miles City Montana 406 232 1370
    390
    flaps
    I have installed flaps on two different 95 cubs. Both had all the welded
    fittings in place. the only work was the wings. both aircraft when completed landed much better, but the take offs weren't any shorter
    with the smaller engs. That said I would have the flaps on one if I
    owned it .Wayne
    Thanks soyAnarchisto thanked for this post
    Jun 2012
    Murfreesboro TN
    10
    Hello,
    Just wondering if you ever installed flaps in your 95' if so how long did it take and appx cost?. I have a 59 model pa-18-95 and am considering it sometime in the future. Mine is plumbed with the pully brackets etc.
    Shelby
    S2D's Avatar
    Montana
    4,253
    I think there was a more in depth thread on this recently
    Bonanza32GF's Avatar
    Aug 2007
    60
    If your PA-18 95 is a light one, please let me know if you take Bob Turner's advice.
    cubunltd's Avatar
    Mar 2004
    Belle Vernon,PA
    1,138
    If you already have the flap brackets in your fuselage, the only weight you'll be adding is the weight of the flap handle and the cables running up to the wing. take the weight of the aileron and subtract the weight of the trailing edge and rib parts you'll be removing, then add the weight of an aluminum bellcrank and it's ttiny mount bracket, two flap hinges and one control rod per wing and thsts approximately how much weight you'll be adding per wing. Not much! for the benefits gained. It's your plane. Do what you gotta do. i would.
    P.S. you don't have to recover the entire wing. Remove the fabric where the flap will be located all around. When done recover that portion covering at least two ribs outboard of where the fabric was cut. Rib stitch, tape, paint, done.
    John
    soyAnarchisto's Avatar
    Aug 2012
    Boulder, CO
    588
    Resurecting an old thread because I have a similar question....
    Having had fuel tanks added to my J3 without recovering the whole wing, I do have a hard time believing that similar surgery couldn't be done on the trailing edge to install flaps.
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    573
    It's a major change to the wing so I'd imagine a recover of the wings would be in order unless you are okay with lots of ugly tape lines and patches.
    That being said I'm firmly in the camp of please don't add flaps to a small engine (light) cub. They really don't improve your landing distances any and mess up the simplicity that is a J3/PA-11. Having recently flown both with and without flaps, your money is best spent burning gas and getting good.
    supercrow's Avatar
    Dec 2008
    501
    Agreed Crash. Many yrs. ago my brother did flaps on a J-3 that was used on floats. Had a flat prop (74-36) on it with an 0200 and it was a great performer on 1500 size float. However, I didn't see a major improvement in other than float use, and I now agree that they shouldn't be altered from original. Just go find a S. cub and go from there. Obviously it is his airplane to do as he wishes but today I wouldn't alter one for anything.
    Aug 2012
    Boulder, CO
    588
    Well, I agree wrt to J3, PA-11, or even a PA-18-95. However, the plane I'm eyeing is a PA-18 105 special, and it's already been modified with a 150HP O-320 but does not have flaps. So we're talking about early super cubs here. My fundamental question is the same as the OP: How much would it cost me ballpark to do?
    My A&P did a fantastic job of cutting in a fuel tank without recovering the whole wing and I was quite happy with the looks of the final result. But it was almost 40 hours of work. Is this same, or more you think? Plus the cost of parts from where, Dakota Cub?
    Quote Originally Posted by supercrow View Post
    10,666
    Dave Hartman did this on the 18-95 he bought a few years back. I don't think he recovered the whole wing?
    May 2012
    SE Montana
    372
    I would imagine it would be at least 40 hours of labor. Might be able to find a set of stock flaps that are already covered, that would save some time. I'd think that flaps would add at least 10k to the value of the plane, so if you could get it dine cheaper than that, it would be worth it. Curious as to what the pros say...
    RaisedByWolves's Avatar
    Feb 2005
    4,430
    Also keep in mind you may need to weld the gross weight tubes. A lot of the early 105ís didnít have them
    windy's Avatar
    Dec 2005
    Utah
    755
    Plus you have to do some more welding here and there to install the pulleys for the flap cables and the flap handle. Iíll bet adding flaps is more than 40 hrs, even without recovering wings. I added flaps to my PA-12, but I did a bunch of other mods at the same time, so I donít have an exact installation time estimate.
    Nov 2002
    Fargo
    790
    If it’s a tango 105 with toe brakes you can’t use the stock flap handle or location.
    Aug 2012
    Boulder, CO
    588
    I'm not sure what a tango 105 is... But this one does have toe brakes. I've not inspected the plane - not sure how interested I am in it - trying to figure that out. But I have read that some of the early PA18's had all the tabs welded in - just that the flaps were not installed. This particular one is a '53 - which is pretty early I think. I'm trying to figure out what to be looking for.
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    886
    By the time you get them installed at Dan's with parts you need, even with brackets. I am guessing you will be north
    Of $10k. Then when you get to the STOL contest some kid
    "With out flaps" that knows how to properly 'side-slip' his will likely easily have numbers lower than yours.........
    As Denny and Reid have already told you the T/O difference with 90hp is negligible. Why would you bother
    To alter a perfectly good original Cub for nothing. This is like taking an original Winchester rifle that's 125 years old and boring holes in the frame because "you think" adding a reciever sight will 'make it better'...... If the Cub has survived for nearly 80 years unmolested, what on earth would ever make you think 'flaps' would make it better.???
    Good Luck with it, but your headed down the wrong road. E
    Oct 2006
    Seldovia, Alaska
    235
    I have a J-3 which has been converted to Pa-11 configuration by STC. It also has flaps also done by STC. It has a 90 and a pacer tail, and VG’s. It weighs 843.
    A low HP cub will not climb as well, haul weight or work altitudes as well as a higher HP cub.
    My light cub gets off the ground as short as most higher HP cubs. The speed at which cub will first fly depends on the wing not the HP. A lighter plane will fly at a slower speed. The HP simply accelerates the plane to that speed. The lighter it is the slower it will start to fly. In many cases a light cub with the right prop will fly sooner than the higher HP cubs with flaps.
    Flaps add additional lift but also add additional drag. The lower HP cubs are not able to take full advantage of the additional lift on takeoff because of the additional drag. Popping some flap may help brake ground but must be bled off promptly on takeoff.
    On the other hand on landing, a light cub with flaps can fly significantly slower and therefor land significantly shorter. Slips aid in loosing altitude, not flying slower.
    If a person wants to be hauling weight a higher HP cub is certainly better.
    If a person is prospecting new and difficult strips he can land in shorter more difficult places with less risk than a heavier cub. That’s not saying he can get out better. Once on the ground often times a strip can be worked onto make takeoff easier.
    If the low HP cub driver isn’t carful he can easily land in places that may be difficult to get out of.
    In my opinion the light low HP cub with flaps is a delight to fly. I find that often I can go places with my flap equipt low HP cub that I won’t go with my heavier 160 HP cub.
    Thanks soyAnarchisto, mixer thanked for this post
    Likes Steve Pierce, 46 Cub, BC12D-4-85 liked this post
    Crash, Jr.'s Avatar
    May 2015
    Anchorage, AK
    573
    It's a 105 cub so not exactly a great loss of a classic if it's converted. On the other hand it is a massive expense and would be better undertaken at time of rebuild rather than with a covered wing and fuselage. Like others have said, there are brackets that need to be welded into the fuselage as well as false spar replacement, rib modification, and adding hangers to the spar. It's no small job and I doubt 40 hours would cover it.
    Really, it would be best to talk to the mechanic who you would have do the conversion to see what it would take or even if they are comfortable doing it. Asking strangers on the internet what your mechanic should charge you is a good way to be on bad terms with a good mechanic.
    Jun 2006
    Alaska
    381
    I’ve read this opinion here a number of times, but I remember when Matt Piatt was getting the shortest landings at Valdez with a light flapped PA-11.
    Catch the fish, to make the money, to buy the bread, to gather the strength, to catch the fish...
    Likes mixer liked this post
    20,845
    All of the Super Cub fuselages I have ever worked on from 1952 model -95s , 125s, 135s and 150 had all the flap pulley brackets welded in the fuselage. Figured it must have been easier on the production line. It is easy to modify the ribs, make a little jig, cut the tails off and rivet the angle to the rib that the false spar attaches to. Personally I wish people would leave the 90 hp Super Cubs alone. They are great flying airplanes for their intended mission but people want a big engine Super Cub and think they are saving money by converting one.
    Likes RaisedByWolves, MZ18, jnorris, TurboBeaver liked this post
    Jun 2006
    Alaska
    381
    Did you fly Tal’s after the flap conversion?
    20,845
    Quote Originally Posted by alaskadrifter View Post
    Yes, only Cub I ever flew that the nose dropped so far when the stall broke. He put the 150 hp Super Cub tail feathers on as well. Tal did not believe in VGs. Paul had them installed on one of his airplanes and they didn't work. Of course when I started asking questions it was at a rebuild so who knows what all was changed.
    2,807
    I put flaps on a PA-11. Added about 20#. Lowered stall 4 mph, but takeoff as noted above wasn't worth the time and cost due to drag and low power (90) to blow the flapped portion of the wing. I could land shorter that the takeoff even with flaps up or popped. Probably helped some on floats loaded if 12* was deployed during takeoff due to lower AOA. Any more and the drag slowed the water run. I'd lengthen the wing before I'd add flaps to that configuration.
    Edit: Prior to flaps the PA-11 had Ferguson droop tips (now CC?) and longer wings. When we redid the wings they were returned to stock tips. I preferred the look of the stock wings.
    Were I to do that plane again I would have left the wings longer w/o flaps but with VG's. The long wings help on floats with low power. I didn't do lots of tight turning in turbulence with that plane so aileron effectiveness was a secondary consideration vs lift.
    Likes supercrow, TurboBeaver liked this post
    Upper Peninsula of Michigan
    646
    I have been surprised how slow i have to get my New Experimental 11 before it starts to sink good....I have balanced feathers and trim tab.....once I hit 55 though she starts to come down ok....I'm putting my VGs on this week, will report the difference. For this reason....I was thinking flaps would be nice a few times....but I've owned Taylorcrafts for 30+ years, so I'm used to slipping. lol. I think the PA18-95 is pretty much the same as my 11 minus the spars coming together above my head, It's been awhile since I flew an 18-95, but I remember it feeling similar to what I built.....I'd keep a 95 stock I guess.....but Soy talks about a 105 Cub with an O-320.....Probably a good candidate for flaps there.
    2,807
    Flaps enhance slow flight no doubt. More nose down attitude at same airspeed. When it stalls mid-to late 30's depending on weight flying at 50 all day is a realistic event. I liked the balanced elevators on my PA-11 (required with flap STC) but they do add pounds.
    I had a flight review on floats that included some harsh tones when I set the downwind at 50 IAS then 45 on final. I had to demonstrate the stall x 1.3 to convince the examiner my sink rate plus airspeed was barely acceptable. Ok...I did give him 55 as a compromise to pass.
    The -95 would be at about 1500 GW floats vs 1350 -11 so maybe add little for safety.
    Likes alaskadrifter liked this post
    RatCub Redux FrankO's Avatar
    Jun 2015
    CDA, ID
    114
    Considering performance on mine & how easily it slips, for the life of me I canít understand why anyone would pollute a 95 Special with flaps.
    Thanks jnorris thanked for this post
    Likes jnorris, Crash, Jr. liked this post
  1. installing 31's
    By teeweed in forum Cafe Supercub
    Last Post: 04-07-2006, 05:49 PM
  2. installing flaps
    By skysigns in forum Cafe Supercub
    Last Post: 12-23-2004, 11:31 PM
