Results 1 to 5 of 5
Thread: Removing or Replacing Fittings and Tabs
    Oct 2005
    Missoula MT
    170
    I am in the process of stretching a tripacer fuselage and was curious what the proper procedure is for removing fittings and tabs. Basically Im curious if it is appropriate to simply cut the fitting and grind it or if there is a more appropriate method. My understanding is that grinding on airframes is a no no but I cant seem to come up with a better method for eliminating unwanted tabs and fittings. Thanks for your help.
    Brad
    Feb 2007
    Arizona, Alaska, S. America, Africa, Iraq, Afghanistan, Various
    117
    I use a die grinder and a 1/16" thick reinforced cut-off wheel. Wear a full face shield - I have a couple of pretty interesting scars on my face from a disk blow up from only wearing safety glasses. Then, smooth what's left over with a sanding disk/flap disk and hand finish when it's getting close. Be careful - if you nick/damage the airframe tubing in any way, it will require repair - a lot of tube walls are only .035"
    Tom
    Oct 2005
    Missoula MT
    170
    Tom,
    Thanks for the input. That was roughly the route I was planning on using. Considering the fact that I am somewhat of a disaster with a grinder its a plus that grinding on airframes is off limits. I have the fuselage cut and will start re-aligining the old tubes to meet up with the splices tonight. Then on to removing a couple of tabs that are no longer needed. Thanks again.
    Brad
    Oct 2005
    182
    Bluepoint(Snap-On) makes a neat cutoff tool that takes a 3 inch disc. It has two positions for angles. Best of all it has a metal safety shield over the disc that doesn't get in the way.
    jay
    behindpropellers's Avatar
    NE Ohio
    6,844
    If I ever rebuild a fuselage I will buy a piloted cutter to cut the tubes out. I have a good selection of die grinders now since I am rebuilding my new fuselage. For the small tight areas I have a soiux pencil grinder with a 1/8" carbide bit on it.
  1. Replacing brake lines without removing leg fabric?
    By UK Cub Nut in forum Tips and Tricks
    Last Post: 01-20-2010, 02:34 PM
  2. Removing/Replacing N numbers???
    Last Post: 07-05-2004, 09:12 AM
