Results 1 to 5 of 5
Thread: PA-12 Baggage Compartment Question
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    448
    I found these pictures of a very nice PA-12 on the net and would like to hear your comments on the way this baggage compartment is made:
    Notice how the rudder cables run unprotected through the compartment. Is this an acceptable way of doing it? It sure looks nice and the folding upper shelf is a good idea, but I don't know about the cables.
    Bent
    eslboat's Avatar
    Dec 2005
    Northern Michigan
    241
    Bent , don't know if it's legal but I personally would want them protected ! I do like all that baggage area.
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    448
    Erik,
    Yes, I think so, too. Maybe one could make half 'pipes' of aluminum,shaped like a C with tabs on it, and fit them over the cables?
    Wouldn't it be wise to cover the aileron cables and the flap cable, as well?
    Bent
    PA12Tray's Avatar
    Bangkok, Thailand
    70
    Extended Baggage PA-12
    In my 12 we ran the control cables under and behind the extended baggage floor and sides. I've put pictures in my photo gallery which may explain better.
    Oct 2002
    Homer, Alaska
    112
    In my PA-14, which has the same floor as a PA-12, the cables are boxed in with aluminum. It is an L shaped piece with a flange on each edge. The short leg attached to the sidewall and the long leg attached to the floor. The aileron cables are boxed in with a shallow U shaped piece with a flange on each edge. Without the cables being protected things could get very interesting, painful, and expensive if they hung up on something.
  1. Baggage compartment
    By twoton in forum Cafe Supercub
    Last Post: 01-12-2019, 03:22 PM
  2. Cruiser Baggage Compartment???
    By WSH in forum Cafe Supercub
    Last Post: 09-30-2007, 06:13 AM
