floats
Central Florida
I use a ramp for my Cub, but to make it easier with water level changes and to be able to use a stationary dock with it, mine floats. It also is hinged and is lifted up out of the water with a winch/cable/pulley system. It keeps the plane up out of the water and waves, and with the turn of a switch (all 12 volt battery powered) it lowers and the Cub launches easily. Plane can be put in either nose first or tail first.
The most important part of using it I think is securing it. I use several 5' screw in anchors and can adjust the lines from the floating ramp when needed for different water depths. Right now I have it setup along side a stationary dock, anchored and tied off to the dock. And I use spring lines to keep it from rubbing on the main dock when the wind comes up.
It can be used in shallow water or deep water, along the shoreline or at the end of a dock.
This was when I used it along the shoreline.
Like Mike says, ramping a plane even with wind is a lot easier than coming along side a dock, keeping the float off the dock and getting tied up. Coming into a ramp with very little power the plane will stick at the top of the ramp, hop out and turn the switch and the plane is up and out of the water in about a minute, everything is very stable and secure.
With the ramp raised, loading and unloading gear and supplies from the plane is even easier than from a dock, with the plane high and dry and not moving in the water. And the ramp can be kept free of slick growth, since it is raised out of the water part of the time. I leave mine down when I'm out flying, but you can use a remote controlled winch and raise it when you taxi out, then lower it when you taxi back to the ramp after a flight. I've got a steel plate attached to the underside of the end of the ramp to sink it. With the winch you drop it to whatever incline works best for your plane.
Gregg Anderson
Oak Harbor SPB
Gregg Anderson
Oak Harbor SPB
