I found this on Harry Fenton's site bowersflybaby.com....I have seen, and believed many opinions on this....what do the rest of you think?
Altering An O-200's Power Curve
I am looking at buying a J3 prodject. Frame and wings almost done sans covering. The engine is a 1500 hour 0200 off of a C-150. All I have been able to determine is that the power curve on a stock 0200 is not the best for a cub type a/c. It has bben suggested to change the cam to a C-90 and get the same power curve as a C-90. It seems there is a question as to what lifters you can use and if a carb. jetting change might be needed. If I get this project I may just run it as is till I get to TBO then overhaul it an make the changes then.
I am wondering if you have any thoughts on this. Have you had any experience with converting a 0200 to have a more C-90 power curve?
There has been the wives tale of the C-90 vs O-200 for years. I strive to base my answers on factual data, and avoid lending credence to the unsubstantiated claims, but there is the possibility that there is some science behind this wives tale.
Nearly 25 years ago, a veteran Continental rep told me that the C-90 cam was a bit hotter than the O-200 cam. The reason? The C-90 was in production when wood props were common, but wood props were not as efficient as metal, therefore the C-90 cam had a bit more aggressive profile to extract a bit more torque to achieve equivalent performance from the wood prop vs the metal prop. When the O-200 hit production, wood props were not used on production planes, so the cam profile was optimized for the more efficient metal props. So, while I don't have hard data to work from, the comments from a veteran Continental engineer that I trusted make the premise that the C-90 cam is a bit hotter than the O-200 cam believable.
There may be an apples to oranges comparison to the C-90 and the O-200 which may appear to be credited to the cam, when, in fact, the cam has no effect. The C-90-8 is a non-electrical engine and the O-200 is usually fitted with a starter, generator, etc. The -8 engine can weigh as much as 20 lbs less than the C-90-8. Less weight feels like more power.
A major hurdle to jump is that the C-90 cam is not a legal installation in the O-200, so you would need to obtain some sort of FAA approval to make it legal. You will undoubtedly be told that the C-90 cam just drops in, which is true in the mechanical fit sense, but it is not FAA approved.
Having said that, let's step away from theory and into the real world. To notice the benefit of the C-90 cam, all things would need to be equal in terms of engine and airframe, and in the Cub world, this rarely happens. Airframe rigging, weight, propeller, engine condition and pitot static system calibration all play a factor in determining comparison performance. A C-90 on a straight, light Cub will perform much better than an O-200 on a heavy, out of rig Cub. Aircraft trim will also play a factor in Cub performance as the trim is controlled by moving the horizontal tail via a screw jack. Due to varying aircraft CG and engine thrust line the trim position will change and affect the overall drag of the airframe.
The underlying theme here is that the C-90 cam may provide some benefit, but either the C-90 or O-200 has ample reserve power to pull a loaded Cub around on a hot summer day. Build your O-200 light and remove the accessories and you will probably be very satisfied with the performance of your Cub.
Harry
