Longwinglover
Charlotte, NC
Is there any paint in a rattle can form that could remotely be called good enough to use as "permenant" paint if one isn't in a situation condusive to setting up the spray gun and mixing a bigger than really necessary amount of expensive, quality paint?
As a primer for a) aluminum or b) steel.
As a finish coat for a part.
Assume that we are talking about parts that wont have much wear from physical contact like the torque tube or a compression tube in a wood spar J3 wing.
If you think there is a possibility of using something, would you use straight from the can or decant into a small paint gun / airbrush?
John Scott
John Scott
