B
bearsnack
I just finished test flying my cub with the modified Atlee Dodge 3" exhaust, gained 40 RPM static and at least 90 RPM on climbout.Climbout phase needs more flight testing as it seems to me this is where it really picks up the power. My 41 pitch I beleive is now innefficient at that RPM (2600) EGTs are down 40-50 degrees and CHT comes down when EGT comes down that much.
I am running a 41 pitch borer which I now need to repitch to at least 43, and get my climbout RPM down around 2475 to 2500.
What was the rule of thumb on pitch, 25 RPM per degree on the 82" borer?
I removed a stock Atlee Dodge muffler that was in good condition.
The beauty of it is it does not weigh an ounce more than a stock muffler, use your stock pipes and away you go.
Atlee Dodge and Glacier Aircraft sells them , my yellow tag says F Atlee Dodge "Hot Rod Muffler" P/N 3241HR
