My brakes on the 'Cruiser, Double Puck Cleveland Disc, are bleeding down and losing pressure after a few days or so but I can't find any sign of the leak. No fluid on the hangar floor, none in the cockpit around the Master Cylinders, none around the brake lines anywhere. What gives? Leaking diaphrams inside the Master cylinders ? They're close to needing new pads again, would that have anything to do with it? Is there a rebuild kit for the Master cylinders?
