.....must...resist....must..not...get..involved...in bernoulii vs newton debate......Arrrggggghhhh...I am weak.
OK, here's the deal:
I don't mean to insult anyone here, but the Bernoulli vs Newton debate is for folks who don't understand the underlying physics.
Bernoulli's principle in absolutely no way, no matter how insignificant, contradicts or is negated by Newtons laws of motion, if fact they are inextricably intertwined in the production of lift.
Yes, the air flows faster over the top of the wing
Yes, as per Bernoulli this results the pressure on top of the wing is less than the pressure on the bottom.
That is lift.
Now, along come the "newton" proponents who say, "but wait the air is accelerated downward, that is where the lift really comes from, it's created by Newton"
well,
of course air is accelerated downward, it can't happen any other way if a force is created on the wing, whether it is created by Bernoulii's principle, Coanda Effect or little green bugs, air has to be accelrated downward.
Newton's laws are not creating the force, all Newton's laws are saying are tha if there is a force on the wing (no matter how it is generated) then there is also an equal and opposite force on something else. In this case theonly something else is the air, so that force is exerted on the air. Another one of newton's laws say that if you apply a force to something which is free to move (and the air is) it will accelerate, so in accordance with newton's laws, the air is accelerated downward by a force resulting in part from bernoulii's principal.
Another type of "lift is newtonian" proponent insist that lift is mostly created by air being deflected downward off the bottom of the wing. This might be true if the air flowing aground a wing behaved exacly like a stream of water from a garden hose bouncing off a piece of plywood. The thing is, airflow around an airfoil is not like that. Air doesn't bounce off the bottom of a wing, in order to grasp what's going on, you have to look at the total airflow around the wing, and understand that the airflow is affected by the airfoil well ahead of the leading edge and well above and below the airfoil. It's not a discrete stream, rebounding off a flat surface. FOr those who favor this view, who claim that lift is created by air deflected downward by the bottom of the wing, especially at high angles of attack: how do you explain a stall? Say a wing has a critical AOA of 14 degrees. At 13.5 degrees AOA, the wing is producing a lot of lift, yet at 14.5 degrees AOA, the lift drops to a small fraction. Why? You should still have a lot of air "bouncing off the bottom of the wing" right? and the angle isn't that differnet, only a degree, so that the trignometry is about hte same, so why does the lift drop to very little? This leads us inevitabley to the conclusion that the flow over the top of the wing has much more to do with lift that "air bouncing off the bottom"
To say that lift is created by one or the other is meaningless. A good analogy would be to argue over whether a car is moved by combustion or friction.
Does the negative pressure suck the covering up off the top of your Cub wings? Mine, neither.
Yeah, it doesn't because the covering is fastened to the ribs. Why do you think so much work goes into rib stitcining?
But just tell me one thing: Why do the molecules that go on top of the wing HAVE to go faster so they can join back up with the molecues that were just below them before the split. What do they care, and how do they know, is what I have always wanted to know. I don't think they really do join back up.
You're right, they don't join back up. The thing is NOBODY says they do! Ok, that's wrong. In all my reading on aerodynamics, (and it's been a whole bunch) I have found exactly one source which says the molecules join back up the trailing edge. The FAA's flight training handbook. It is wrong. They do not join up. This has been known as long as there have been wind tunnels. However, the airflow on hte top of the wing
is faster than the airflow on the bottom, this is an absloute fact. This also has been know as long as there have been wind tunnels.
