Results 1 to 10 of 10
Thread: I need a better tailwheel tire
    slowmover's Avatar
    Nov 2003
    Little Rock, AR
    339
    I have changed about three or four tubes in the past year due to flat tailwheels caused largely from crap in the grass at thestrip that I choose to operate off of. I am running the standard tailwheel tire and tube. Short of changing airports, which really isn't an option, is there a better tailwheel tube/tire combo that will keep me fm getting flats?
    It is a little humiliating for me to admit this, but I think I have more problems with the tailwheel than the 172 drivers that use the same area.
    I'd appreciate any creative suggestions...
    Ursa Major's Avatar
    Oct 2002
    Coeur d'Alene, Idaho
    1,078
    Re: I need a better tailwheel tire
    Quote Originally Posted by slowmover
    Try some fix-a-flat. I've used it on Bushwheels and other tires for thorns and other small stuff. Works pretty well.
    Oct 2003
    CANBY, OR
    176
    theres a tube sealant you can add to the tube before puncture. I think its called Slime. Remove the valve and squeeze it into the tube. It will seal holes as they occur.
    Scott
    Aug 2002
    Talkeetna Alaska
    283
    In my experience the three most common causes of tail wheel flats are:
    Low tire pressure.
    Camber out of alignment.
    Wheel damage, causing tube pinching or chafing.
    Good luck.
    slowmover's Avatar
    Nov 2003
    Little Rock, AR
    339
    Yes, but my problem is that I keep running over small sticks or thorns that puncture the tube.
    I flew 600 hours in three years in Alaska and never had a flat.
    I have had four in 100 hours in Texas.
    Jan 2004
    Rimouski,Quebec
    142
    You can change your tailwheel for a hardrubber maule, that`s what i use on my J4 and never had a flat tire!!
    Frenchy
    new jersey
    72
    Baby bushwheel, I have used them for three years and never looked back. I average between 250 to 300 landings per week and the scott tailwheel tubes would blow out far to often. I used to take an old tube cut off the valve stem, slit it around the center and make a sleeve, place it inside the tire,then install your new tube inside. That would help with the chafing, Make sure you have the correct tire pressure. Hope that helps...
    jk's Avatar
    Dec 2002
    over there
    480
    "SLIME" it. Good stuff. Available at auto parts stores.
    JK
    7,370
    I had a similar problem on the Dec - finally got a second wheel/tire assembly, and lashed it, along with a 3/4" wrench and a fresh cotter key, under the back seat. End of problem!
  1. Changing tailwheel tire
    By Jr.CubBuilder in forum Tips and Tricks
    Last Post: 03-29-2018, 03:18 PM
  2. Airless tailwheel tire
    By S2D in forum Super Cub Sick Bay
    Last Post: 01-12-2005, 01:26 PM
