Results 1 to 3 of 3
Thread: Correct prop torque for McCauley prop
    OVEREASYGUY's Avatar
    May 2005
    New Gloucester, Maine
    423
    I'm putting on a new McCauley Prop on my 160 hp supercub.
    does anyone happen to know the torque specs on this prop? (for 3/8 inch bolts)
    the old one sure came off easy - so i'm guessing with the fine threads they don't torque them very much? ?
    I found a chart on Sensenich Props where on 3/8 inch bolts (which I have) they recommended 23 to 25 lb-ft
    thanks
    cliff
    N82225 in Maine.
    Sep 2005
    timmins ontario
    219
    TORQUE
    22 lb-foot 3/8 dolts same prop on 85 cont ,better to be safe and check for 160 hp. Make sure to wire up properly and check tracking.Get hole instructions from your mec .I would also retorque after couple hours of
    operation just to be safe
    Dec 2005
    Fairbanks, AK
    280
    Cliff,
    McCauley SB 227 lists 30-25 ft-lb dry torque for the 3/8 bolts.
    I have seen plenty of stretched propeller bolts from He-Man torque. Did you get new bolts with your propeller? The thread length of propeller bolts is different than standard AN bolts...
    Vickie
  1. McCauley Prop Weight?
    By wingnut18 in forum The Art and Science of Flying
    Last Post: 11-20-2009, 11:41 PM
  2. McCauley seaplane prop pitch for C85-8F?
    By gcgilpin in forum Tips and Tricks
    Last Post: 07-23-2006, 01:26 PM
