Results 1 to 9 of 9
Thread: how to breakin channel chrome cylinders?
    Oct 2005
    port lavaca,tx
    109
    anybody have any expertise?
    Apr 2005
    Woodstock , Ontario
    223
    channel chrome
    Full throttle, good cooling and lots of time. Don't apply high loads until oil temp has come up, or glazing could occur.
    Ron
    Oct 2003
    Hometown USA!
    592
    Run'em hard and don't super cool em!
    But then again whada I know.....
    Sam
    Steve, ciò in incognito è molto buona!
    Nessun non ho spedito il vostro vino....Ma mantenga la fede!
    nanook's Avatar
    Aug 2002
    northern alaska
    1,685
    Break-in
    Run your engine at 75% power or more. The higher the manifold pressure the better= a cruise prop at low altitude(for normally aspirated)
    You are breaking in iron rings(soft) against a gawdawful- hard chrome surface. The amount of channeling in the chrome(egg shell pattern) really determines how well they work, too much channelling and they use oil, not enough and they don't hold the proper amount of oil for lubricating/cooling...
    NC
    1,048
    Chrome cylinders...
    Years ago, I put a set of chrome cylinders on a C-90 powered Clipped wing cub. The first flight scared the dickens out of me as I almost ran out of oil in a one hour flight. Oil consumption was on a steep downward curve, however. At 100 hours, it didn't use any oil at all, and I never had to add any oil between changes after that. Amazing what a little time/use will do.
    Mike
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    15,017
    Quote Originally Posted by Sam Beckett
    Nessun non ho spedito il vostro vino....Ma mantenga la fede![/b][/color]
    HA! Thanks Sam.
    (P.S. I don't read every post, but I did read this one...)
    Mikey's Avatar
    Everett, WA
    518
    My O-320 w/ channel chrome took about 10hrs cruising at 2700. Then ran the next 15hrs at normal high cruise settings. Oil consumption got down to about 8hrs/ qt after 50+ hrs. You will think you have a fuel leak when you start out, mine burned about 10gph at the readline setting.
    Chris
    cubunltd's Avatar
    Mar 2004
    Belle Vernon,PA
    1,138
    Make sure you use mineral oil for the break in period.
    John
    76
    take multigrade mineral oil that helps a little bit against glazing. Start the engine make a short precheck, firewall it, climb to 5500´level off and fly with full throttle or about 75% for the next 3-4 hours. That´s what Webber (Old time enginerebuilder) in Wassilla AK told me years ago. I am using now around 1 quart every 6-7 hours but I have not to worry about cylinderrust when my bomber sits on the ramp for month
  1. Chrome?
    By supercub in forum Cafe Supercub
    Last Post: 08-20-2009, 06:54 AM
  2. New overhaul breakin
    By Bwillis in forum Cafe Supercub
    Last Post: 01-29-2006, 11:47 PM
