Thanks Thanks:  0
Page 2 of 2 FirstFirst 12
Results 41 to 80 of 80
Thread: C-90 Performance Mods
  1. #41
    Apr 2005
    Woodstock , Ontario
    223
    engine
    Roger: Define loud. Exhaust or Continental mechanical noise?
    Ron
  2. #42
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    No more than normal mech noise. The main noise is the four into 1 exhause on a non standard engine.
    I started with a standard 0-200 engine. I purchased new continental cylinders and sent them to Light Speed Engineering in Santa Paula Ca. Klaus Savier of Light Speed then installed his forged pistons with a 9.4/1 compression ratio. Did a ring and piston fit. the top clearance on the pistons was accomplished by grinding the combustion chamber on some of the cylinders. The intake and exhaust ports were then ported. The valves were then 3 angle cut on all seats and valve faces. The connecting rod were shot peened and balanced and line-bored to fit the larger wrist-pins and balanced. I then installed a electronic ignition by Klaus in place of the right mag.
    The plane is made to standard PA11 plans except for the electric trim, seats, and a full panel. Plus a few other mods.
    There are a few pictures of the construction on www.pmmi-inc.com/planes.html.
    Don at Sensenich made a 72/50 wood prop for cruse and a 80/20 wood prop for floats. The cruse prop gives me a top speed of around 115 mph and the float prop will curse at about 75 mph. The wings were purchased from Dakota Cub and mounted to the plane using Super Cub Struts. Since I did not install a jack screw for trim, I put double tail brace wires on the tail. Other than that it was std construction. I did use some ultralight fabric to install a fishing rod carrier which you can see in the pictures.
    The 4 into 1 exhaust was made for me by Chris Stepp at Aircraft Exhaust Technologies. He has some pictures of it on his web site at http://www.aircraftexhaust.net/. He really did a nice job and it gave me about a 100 rpm adder. I also installed Micro VG's on the plane which lowered the stall by a full 20%.
  3. #43
    May 2004
    Sweeny, Texas
    1,454
    Made a little typo. The float prop is a 80/27.
  4. #44
    R. JOHNSON's Avatar
    DODGEVILLE WI
    372
    Roger, do you feel that the increased performance with the 4 to 1 over the stock system is worth the money if you had to do it over? Also if you had to pick either the elect. ignition or the exhaust what would you go with? Also how much horse power is your engine putting out? Thanks in advance for your time, Ryan.
    EDIT: I think you answered my exhaust question when I seen in another post you've had three sets. I have another question though, have you thought about trying the J-3 mount for the zero degree thrust angle? Thanks, Ryan.
  5. #45
    May 2004
    Sweeny, Texas
    1,454
    The four into one gave me the most boost for the buck. Picked up 100+ rpm when I put it on. I would not go to the 0 thrust. Have tried it and picked up very little. Like the added performance getting off the water with the 4 deg of look down. If I want to go fast, I get in the 172 with my wife. She won't let me fly, but she lets me ride.
    The homebuilts are really nice, because you don't have to guess what works the best, just go try it. By the way, my PA11 can keep up with the 172 but I have it looking at the ground at that speed. I think I am putting out about 120 to 125 hp, but my fish that I caught last summer get bigger when I get back to Texas.
  6. #46
    Cub junkie's Avatar
    My Moms basement
    2,124
    Roger,Do you like the trim you have opposed to the jack screw system? Were you trying to eliminate some of the headaches associated with maintaining a jack screw system? Kevin
  7. #47
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    107
    C90
    Roger- I have been looking at the 4 into 1 exhaust as well. I currently use a Luscombe 2 into 1 setup off an 8E. It works well and is also loud (but I like that). I wonder If I would get any gain over this setup? It is very free flowing.
    Any issues with Claus' pistons? I have a set of C85 pistons moly coated that I was planning to use but the 9.5 to 1 sure sounds like it would be a huge gain. The C85 trick probably adds 5-8 hp but only adds a little to the compression ratio.
    How much time is on your engine? Any problems so far? You have done all the mods I have been wanting to try-
    Eric
  8. #48
    May 2004
    Sweeny, Texas
    1,454
    I used the electric trim just so I could get the control on the stick and have a real fine trim control. The only trouble with my system is that the trim tab is about 4 times as large as it needs to be but don't want to rebuild the elevator.
    I think the 4 into 1 collectors that Chris builds reall pull a vacuum on the remaining 3 exhaust tubes and help cut down on back pressure.
    I have had no problems with the engine and the pistons seem to work fine. I only have about 125 hr on the engine. Flew it to Canada and back and on floats for the summer. I am getting good oil analysis back but my oil usage is only about 1 qt in 25. Would like it to use a little more oil. The oil does not turn black like my other planes. Will know more in a few years but for now it is really a smooth engine without any vibrations at any speed.
    About the only change I would make is to the Float plane prop. Should be a 80/32. I turn about 3,000 wide open and 2850 on lift off.
  9. #49
    Aug 2005
    western Washington
    531
    Someone posted this link on another discussion site- it's from the Flybaby website and has some good poop on the small Continentals.
    www.bowersflybaby.com/tech/fenton.htm
    Rooster
  10. #50
    Sep 2002
    1,621
    >C85 pistons are flat topped, and are about 1/8" taller than O-200 (pin to top). Normal compression is about 6-1 with O200 pistons,
    7.0:1
    > running C85's takes it to about 7/7.5-1?....sorry I don't know the exact number.
    8.7:1
    ? LyCon's are a domed top piston that run up to about 10-1 and take special rings.
    Lycon flat-top 9.5:1 ----- can't get 10's for the O-200. I'm running 9.5:1 Lycons in an O-200 that I'm building up now.
    Lycon pistons have 3 rings vs. 4 rings for the C-85 pistons.
    Gapless rings are made by Total Seal to fit about anything imaginable.
  11. #51
    Sep 2002
    1,621
    Fireball, stumble on throttleup and quitting at low rpm during taxi are both often a result of running an A-65 spider on the C-85 and C-90. About a fourth of C-85's seem to be using 65 spiders. You can tell a 65 spider by the abrupt external neckdown in the throat. The 85, 90, and O-200 spiders have a uniform diameter throat. If you have a C-85 spider, polish it.
    The cheapest solution is to throttle up more slowly, take about 2 seconds to shove the throttle in.
  12. #52
    acroeric's Avatar
    Nov 2005
    Burlington, NC
    107
    Vaccum pump gear? Leave it out?
    I am assembling my C90-12F engine and am considering leaving the vacuum pump gear and housing out. In looking at the oil flow I think as long as I have a well fitting blank off plate it should work fine- Anyone know of a reason I should not do this? I am sure the engine would pick up a little hp without the friction of the gear plus I loose a pound or two off the engine.
  13. #53
    Sep 2002
    1,621
    Quoted -- "Normal compression is about 6-1 with O200 pistons, running C85's takes it to about 7/7.5-1?....sorry I don't know the exact number".
    Normal compression for C90/O-200 is 7.00:1
    C85 pistons with C90/O-200 crank gives 8.68:1
    Klaus Saviar pistons 9.4:1
    NFS pistons 9.5:1
    9.5 pistons with no changes in timing or jetting will give a 9.76% increase in power and torque.
  14. #54
    tcraft128's Avatar
    May 2006
    St. Marys GA; GA36
    803
    Make sure you plug those holes where the gear bolts on.
    Turning money into noise since 1996
    Our Build here
  15. #55
    Mar 2006
    canada
    86
    Quote Originally Posted by acroeric View Post
    Besides using C-85 pistons and the p/n 530788 35 degree overlap cam (approved cam - just hard to find) what other mods are being done to increase the power from the C-90's? Mine is a -12. I have heard that using a intake spider off an A65 and grinding it to make it flow better also helps. I do not want to do anything that has not proved reliable.
    why a A65 spider? there a lot smaller throat then the c-90 ?
  16. #56
    3,222
    There's a lot of info on Continental 4-bangers -- what fits what, performance mods, etc-- on this webpage:
    http://www.bowersflybaby.com/tech/fenton.htm
  17. #57
    Sep 2002
    1,621
    A65 spider has an external and internal stepdown in the throat that the 85/90/O-200 spider doesn't have. Opening the 65 spider up for 'improved' flow will cause it to crack at the stepdown due to over thinning the throat wall.
    Read the two paragraphs under 'Cam Design Changes' on Page 1 of SB M49-17 and note that Continental explicitly says that the 24° cam gives more power and better acceleration than the 35° 788 cam.
ID:	28264   Click image for larger version.
    Attached Files Attached Files
  18. #58
    Mar 2006
    canada
    86
    that's why I was asking why someone would use a A65 carb spider
  19. #59
    Sep 2002
    1,621
    As an aside, the stock O-200 cam gives more power and torque than either of the C90 cams up to a density altitude of about 9400-10,000 feet. At sea level, according to Continental, anytime the O-200 is between 2150 rpm and about 2900 rpm, it is producing more torque than the peak torque of the C90.
  20. #60
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    2,480
    Quote Originally Posted by JimC View Post
    Jim,
    Would you say that Continental's statement on the -788 cam is based on the stock engine and exhaust, so depending on what other mods one may install, the -788 cam may well provide a benefit? Most engines benefit from breathing easier, hence exhaust mods are typically first, and then intake mods may follow.
  21. #61
    Sep 2002
    1,621
    "Most engines benefit from breathing easier"
    I would agree with that, and the 90's 24° cam would also benefit from that as well. As would the 35° cam of the O-200. Continental did not dyno these engines with the J3 or PA11 exhausts installed. My personal preference is for the sharper lobed O-200 cam, but that's because I never have to launch at density altitudes above 10,000 feet. The 90 cams will outperform the O-200 cam when the manifold pressure drops below 21 inches.
    I typically prop the O-200 to give a 55 mph climbout between 2500 and 2800 rpm and an 79-81 mph cruise at 2250-2350 rpm. In a J3, I'm leary of a 55 mph climb at more than 2800 rpm with much less than 3 gallons in the nose tank for fear of unporting the tank outlet during the climb. At 2800 rpm and 55 mph, the J3 deck angle is very steep.
    I've designed an offset J3 'muffler' that fits within the stock heat shrouds (so looks externally stock with shrouds mounted) but doesn't muffle and flows somewhat better than stock while also clearing the -12 oil screen housing. I haven't built or flown it yet, but am looking forward to doing so. I haven't given any attention yet to the 11 exhaust.
  22. #62
    2,517
    Better suck and blow help performance. Here's my choice for air filters...as close to an open system as I've tested for static rpm on a C-90 with their P10-7150 FFA/PMA element:
    http://donaldsonaerospace-defense.co...dfs/007217.pdf
    Gap
  23. #63
    Sep 2002
    1,621
    So, with a volumetric efficiency of about 0.8, at 2800 rpm the 90 and O-200 will pump about 130 cfm. That gives an improvement of 0.4 inch of H2O over the Brackett, for about a tenth of a percent increase in power output. About 0.1 to 0.15 hp. That's about a 2 fpm increase in the J3's rate of climb. Every bit helps.
  24. #64
    10,299
    I haven't had an air filter on my J4 for the last 900hrs
  25. #65
    2,517
    On pretty much a standard August day at 425' MSL, 72F, 29.85" Hg from set to 0' on altimeter...MP gauge read 30.10" Hg. Nosed into the bank on floats...fresh C-90 in a PA-11. Prop Sen 76AK-2-40. Used digital remote sensing Proptach sitting on panel. Here's the WFO static data I recorded with a new Brackett filter element and new Donaldson P10-7150:
    Brackett 28.5" 2300 rpm
    No air filter 29" 2325 rpm
    Donaldson filter 28.9" 2320 rpm
    Every little bit helps.
    GAP
  26. #66
    2,517
    Probably not many volcanoes or blowing dust where you live?
    GAP
  27. #67
    Sep 2002
    1,621
    I agree wholeheartedly about the every bit part.
    So, the chart and text in the link was wrong?
    (it doesn't jive with your numbers - it gives a half inch of water difference for 130 cfm, and you are seeing a half inch of mercury - big difference)
  28. #68
    2,517
    (it doesn't jive with your numbers - it gives a half inch of water difference, and you are seeing a half inch of mercury - big difference)
    Well that's what went down for me, not sure what Donaldson did but I suspect they used a flow bench and not a real engine. I repeated the test forwards and then backwards the same day...same results. The Brackett has two potential flow issues...the foam element (mine was unused) and the backing/anti-backfire louvered metal plate. Both are restrictions versus an open air box. I didn't try just the Brackett filter without the foam element. The Donaldson and K&N/Challenger filters don't use the metal backing. Later I compared the Donaldson vs Challenger in that PA-11 and saw no detectable difference.
    I also compared the Brackett versus the Donaldson on my current C-85 Stroked Taylorcraft w/C-150 exhaust, newly rebuilt tight airbox, and saw similar static results with the same prop...Brackett about 2415 and Donaldson about 2440. The rpm bounces around some but the Donaldson again offered about 0.4-5 "Hg manifold pressure and increased static rpm. Yes the static is above TCDS specs and a hundred or so over my previous PA-11 with C-90. Not all engine installations are created equal.
    Edit: I install MP gauges to quickly detect carb ice and monitor MP at idle and WFO. Lower is better at idle (10-11"); higher better WFO (I like to see no more than 1" Hg system loss) and as close to ambient air pressure as possible. It's just a way to note a tight engine and infer volumetric efficiency.
    GAP
  29. #69
    10,299
    On my other cub I still use the original folded media wash and oil type, last forever
  30. #70
    Sep 2002
    1,621
    I don't like the brackett either (except in very, very dusty conditions).
    I typically see about a 25-30 rpm static difference between the Brackett and no filter.
    I'm thinking about a C150 exhaust for my O-200 11. How is it working out for you?
  31. #71
    2,517
    The only comparison (and a loose one at best) is between my former PA-11 C-90-8F with the Piper exhaust and my current C-85-12F Stroker with the Cessna C-150 system...static rpm was higher on the latter with the same intake and internals (I have a C-90 cam in the Stroker). I assume Cessna and Continental did their best to get power out of the O-200 while providing heat for the cockpit. So yes I'm happy with the system. The headers can be curved inwards some (Atlee did mine for the builder) to fit a tight cowl.
    Another option that may fit better would be the Luscombe exhaust: http://www.acornwelding.com/pdf/Lusc...del%208E_F.pdf or similar. Good reports on these as well.
    More on this: http://luscombe.org/technicaldocs/ba...t%20system.pdf and http://dc65stc.blogspot.com/2010/09/...onversion.html
    GAP
  32. #72
    Sep 2002
    1,621
    Main advantage to the C150 exhaust is that I have one lying around.
    Are you running the 788 cam in the Stroker?
    Or the 24° cam?
  33. #73
    2,517
    Main advanage to the C150 exhaust is that I have one lying around.
    Or the 24° cam?
    Well if the C150 exhaust is sitting there then have a go at it...might take some fitting and as I mentioned the headers can be bent closer to the engine. I'm running a C-90 forged cam and required lifter bodies in a C-85 case machined for them...I assume it's a 531076 with 24* overlap (others did the work). The SBM47-16 (Rev. 1960 Supp. No.1) and M49-17 discuss this. Magneto timing to the upper range of acceptable tolerance is important.
    Edit: I'd also experiment with exhaust stack length at some point. See if exhaust reversion timing can affect power in that installation.
    GAP
  34. #74
    Sep 2002
    1,621
    "Magneto timing to the upper range of acceptable tolerance is important".
    True. In one O-200, I run 28° BTDC with the 9.5 pistons and the 35° overlap O-200 cam. Am thinking about advancing a bit more. Other O-200 is stock.
  35. #75
    2,517
    Seeing as how mine's still wearing a C-85 data plate under TCDS E-233, 28R/30L* is the legal upper tolerance range (+-1*) listed for a STC SE00979AT Stroker. Not sure what an O-200 would tolerate. I'm not an A&P so I just throw $ at the builders.
    GAP
  36. #76
    Sep 2002
    1,621
    I pull a cylinder and look at the pistons ever hundred hours or so. I suspect the 9.5 O-200 would tolerate 28/30, but haven't actually tried it. Wanted to build up a few hundred hours at 28° first. It's also bored 0.015" oversize. So far, so good. Tried Total Seal rings, but couldn't get the valve guides to quit leaking oil due to the increased suction. With them, got a puff of blue smoke every time I cobbed the throttle.
  37. #77
    2,517
    Pre-detonation might manifest itself on the piston tops...pocking and irregular carbon coverage...so if it looks good then fly more. I guess I'd rather have a little more oil on the guides as long as they aren't coking and as a result show offset of the valves. How do the inner valve covers look? Any sign of excessive exhaust blowback through the guides and seals and uniform between cylinders? Are the exhaust valve faces uniform in discoloration and seating/cooling well?
    I wrestled with installing higher compression pistons than 7:1 with this latest engine but decided against it as I wanted durability and not to expose the builder to undue scrutiny. Cooling then becomes more critical too. So it works well enough.
    They did something to the center main cross-bolting to help it hold hands better, but I expect it wasn't a complete through bolt like the larger engines. The carb is a MS but without jetting mods one has to be careful with A/F ratios feeding power produced.
    If I did it again I'd probably try the Luscombe exhaust (maybe with a crossover tube between stacks for a 2-1-2 setup) unless someone has dynoed one and found a loss of performance over a C-150 system.
    GAP
  38. #78
    Sep 2002
    1,621
    No noticable blowback through the guides. Valves and seats look and seal good (I run 93 octane mogas with ethanol). Carb is an MA3-SPA 10-4115 with brass float. 9.5 cooling is not an issue on a J3 (no intercylinder baffles), but I don't think I'd be comfortable running more than 10.0:1 pistons on mogas at advanced timing.
  39. #79
    2,517
    Ok Jim I missed the J-3 part...so an exhaust external to the cowl is not an issue of fit I assume. Well I'd surely experiment with exhaust to see if there's any benefit to be gained.
    How's your mixture distribution between cylinders? Do you see any visible color differences on the internals or EGT spread? If so, how have you dealt with it? I was thinking of having Atlee X the outlet of the airbox to maybe straighten the flow into the carb but forgot when it was time to have it done. I don't have an EGT.
    Prop...I've read here and elsewhere about which pulls the best...what's your current preference in a Sen or Mac? Lots of Cattos have migrated north to Alaska but I'm reluctant to try just yet.
  40. #80
    Sep 2002
    1,621
    The C150 exhaust would have been for my 11, not the 3.
    Mixture distribution seems OK - no signs of temperature distress, runs very smooth. J3 is non-electric, so don't have good figures on CHT/EGT. Were they bad, I think it would have shown up during recurrent internal inspections.
    Mac 7440 seems to outpull everything else up to 2700 rpm. Above that Mac 7535 comes into its own.
    I'm curious about Catto, but no experience.
  1. J-3 mods
    By JimC in forum Modifications
    Last Post: 11-19-2006, 10:11 AM
