Results 1 to 7 of 7
Thread: Radio noise, radio needed
    Jul 2003
    Hempstead, Texas
    506
    I posted earlier about some static in my KY92 comm.radio. I have check all I can and I still have the static so it is time to send it off unless any one out there has a KY92 they want to sell. I missed the bidding on ebay for one this afternoon. Thanks Mark
    Lawn Dart's Avatar
    Apr 2002
    Las Vegas, Nv
    524
    Teeweed, before you put that radio in the shop, try these things:
    1. Head over to the hardware store and get some 0000 steel wool (henceforth 4ot). Then head over to Radio Shack and get some contact and point cleaner. After that, head to Big 5 or Sports Mart and get a plastic .22cal barrel cleaning brush.
    2. Take the 4ot and buff the plugs on your headsets to a bright finish.
    3. After youíve buffed the plugs on the headsets, spray some of the contact cleaner on them and dry them with a clean towel.
    4. Spray some contact cleaner on the barrel brush and swab the contacts in the female sockets for the plugs.
    5. Disconnect and reconnect the radio to tray connection, the coax to radio tray, and the coax to antenna several times to ensure that they have a clean connection. Use the contact cleaner at these points also.
    If you have Slick mags, this might help. If you have Bendix mags, check your filters.
    Hope that helps.
    PS Oh boy, here we go!
    Seaworthy's Avatar
    Feb 2005
    Massachusetts
    1,543
    Noise
    Hmmmmmmmmmmm. I have the same problem. Only starts after the engine running for about 15 min and at high RPM. Oh--------only on xmit. RCV is clear as a bell. I've been told it's mags. I have new Slick mags.??????
    Marine Corps Aviation since 1966
    Lawn Dart's Avatar
    Apr 2002
    Las Vegas, Nv
    524
    I also have Slick mags and I have the opposite problem. Recv is garbled and tx is clear as a bell.
    But if I don't clean the terminals every few months, all is bad.
    Jul 2003
    Hempstead, Texas
    506
    Thanks Lawn Dart I will do as you suggest. My mechanic came over and we check several things. He finally turned down the squelch
    volume from a small hole on the belly of the radio. I don't think that solved the original problem but it might make it so that the static is not so loud when I am flying. Thanks Mark
    jrussl's Avatar
    Jul 2005
    Madison, WI
    551
    Radio Noise
    Lawn Dart,
    You mentioned to "check your filters" if you have Bendix mags. What exactly do you mean?
    Let me explain further. I just purchased a SuperCub and replaced the Valcom radio with a Garmin AT SL40. With the engine off, the radio works fine. With the engine running, all I hear is static. I have the same issue with a handheld unless I hold it way behind my head over the passenger area.
    My path right now is to fix some fraying sheilding where the p-leads go into the Bendix mags. I have also been told from another source that it may be a problem with the ignition harness.
    I have seem magneto filters for sale that attach to the p-lead attach point on the Mag but figured I would try that a few steps down the road. Based on my limited inspection, it does not appear to have any mag filters installed now.
    Let me know if you have any insight into this. Any help would be greatly appreciated.
    The other Jeff Russell
    Lawn Dart's Avatar
    Apr 2002
    Las Vegas, Nv
    524
    Guys, Iíve scanned some pages from a magneto book that explains it.
    PM me with your email address and Iíll send them to you.
    Also, donít forget that noise can come from lots of sources, spark plug leads, alternator, etc.
  1. Radio noise?
    By bob turner in forum Tips and Tricks
    Last Post: 09-04-2008, 08:47 AM
  2. Radio noise
    By Gizmo in forum Experimental Cubs
    Last Post: 08-28-2008, 02:08 PM
Tags for this Thread
