Hi All,
I have 4 new Lord J-7402-24 dynafocal engine mounts on my O320 E2D in my PA12. The problem is that the top mounts sag approx 1/4" when the weight of the engine is on them. Lord says that max sag for this series mount is 0.060". Has anyone experienced this before? I've checked with Lord and learned there is no difference between the inner and outter mount, ie; compression or tension. This mount has the jell filled spacer installed in all four mounts. Any ideas why the mounts may be sagging? Thanks in advance.
Ron
Ron
