Results 1 to 19 of 19
Thread: Vacuum system installation
    janboc's Avatar
    Sep 2004
    Poland - EPBC
    34
    I decided to get rid off old electric AI and go into vacuum system in my PA-18 with O-320-B2B engine - registered in normal category. Can you recommend me all the necessary parts and gauges?
    TNX
    J
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    Garmin 296. Crash
    Clearwater,Fl
    2,545
    Look in a 18 parts manaul. They are very helpful and affordable. Everything you need to know in detail is listed there -correctly.
    T.J.'s Avatar
    Apr 2002
    Alaska
    3,211
    As long as your not flying in the ice much, go with a venturi. Trouble free, no moving parts and no ADs on them.
    7,020
    Crash is right. The venturi works well at around 100 mph; it can drive all three gyros. But I wonder if the feds will ever figure out that it is airflow you need, and not inches. There is no engineering data on the venturis.
    The Garmin is a wonderful backup. While not legal for IFR flight, it has a horizontal flight director that makes an ILS a real snap! The HSI presentation is hard to beat when things get tight.
    Also, what about those new $2000 solid state AHRS deals? Sure, they are not TSO, but I bet they will be in a couple of years! Save weight, look great! The solution! Glass is saving the airlines big bucks, and has been for about 20 years.
    janboc's Avatar
    Sep 2004
    Poland - EPBC
    34
    Definetly I need to have something "legal", once a year in(p)sector puts his head in the cabin Btw. I use GPS as a backup.
    Parts manual for PA-18 shows different installations from the past and will be tough to get all the items.
    I loooked to the various manufacturers (God bless google) like Airwulf, Sigmatec, RC Allen - most of them has pumps, gauges, hoses, filters etc - but I want to have the working configuration that will work for a copule of years.
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Agree go with venturi. No pumps, no regulators, no valves, no suction gauges, no failures, no maintenance $. One gyro, one venturi; two gyros, two venturis; no sharing, no cross over. KISS principle.
    BTW, to avoid having to answer the same stupid question over and over, stick a sign over the venturi that says " NO, IT'S NOT A HORN"
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Need venturi advice.
    The other day ATC gave me a heading to fly. Easy for you to say - I grumbled. My whiskey compass is reliable +/- 180*. Anyway, it looks like I'll have to go for gyros if I want to fly in "civilized" airspace. I can't afford electric, don't want a vacuum pump, and have no room for low-suction AN gyros. So I'm thinking dual 9" venturis, one on the left, one on the right just above the cowl gills, merged into a 1/2 x 3/3 x 3/8 wye, a regulator, then branched off to two 3/8 lines, one for an AH, the other for a DG + needle-valve and T&B. All air intakes from one common filter. Or dual 8" venturis and no regulator.
    My present 4" venturi pulls 2.9" Hg @ 80mph - taken directly off the venturi. I'm told 9" super venturis pull about 6-7" @ 75mph.
    Any thoughts? Experience?
    10,813
    Whatever you do, stay away from RC Allen gyros. Unless they've improved a lot recently, you'll be spending a lot of time and $ replacing them. Personally, I would stick with a GOOD quality electric AI, especially if all you need is the AI.
    1,965
    Go digital with a RCA2600-2 It is not cheap but dirt simple and in the long run cheaper and a lot lighter than trying to stick in a vacuum system.
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    670
    I'd recommend a Dynon D1 or D2 unless you are getting set to fly IFR with it. Clips into a 3 1/8" instrument hole or onto a RAM mount. Only uses milliamps of power and weighs a whopping 7 oz. Provides loads of information, including heading, GPS altitude, vertical speed, pitch, roll, slip/skid, turn rate and GPS speed. Also has 4 hrs of battery life if the power goes off. I find the roll on mine to sometimes drift off 3 or 4 degrees before it corrects itself, but I've been flying with a D1 for a little over a year in my other plane and love it. The D2 provides a g meter and wi-fi if you like to display this stuff on your tablet.
    -CubBuilder
    1,965
    Another good choice my buddy has one and loves it
    9,972
    All solid state. All in one 3-1/8" instrument. Weighs next to nothing. All electric using almost no electricity. Works great. Gets the compass information from your GPS. http://trutrakap.com/product/gemini/
    I have the early version in my Cub and would have no hesitation in recommending to others.
    RaisedByWolves's Avatar
    Feb 2005
    3,983
    Quote Originally Posted by Aviator View Post
    Why not a garmin portable GPS? You can have pretty accurate heading and alt. my compass can be a pita sometimes and not show the right heading. Plus you wouldn't have to add a bunch of weight.
    Mine had an attitude indicator and dg when I got it. Powered by a Venturi. It sucked. It was mounted on the boot cowl, left side. I think that's the stock location. Didn't work that great, pulled it all when I got it. No need for it. I won't be flying IFR in that airplane, and it didn't seem to reliable.
    19,344
    I'm with Tom, that is what I use.
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Thanks for all the advice, folks.
    kiwicubber's Avatar
    Jun 2007
    Te Kowhai, New Zealand
    144
    I’m restoring a PA-18A-150 with a vacuum system and Univair don’t have the regulator valve part no. 756 764. Can anyone suggest an alternative regulating valve please?
    cheers Bill
    Bill and Neroli.
    www.supercub.co.nz
    2,972
    Rapco or Tempest. Different part numbers are different hose sizes and number of connections.
    Thanks kiwicubber thanked for this post
    Likes mike mcs repair, kiwicubber liked this post
    3,039
    I've got 2 vacuum regulators, a Pesco and a Manning Maxwell & Moore.
    PM me if youre interested.
    Likes kiwicubber liked this post
  1. Rail System Installation
    By Roger Peterson in forum Cafe Supercub
    Last Post: 12-08-2006, 08:07 PM
  2. Vacuum Instuments Too Far Gone?
    By Flying Miss Daisy in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 06-16-2006, 05:47 PM
