Can anyone tell me what length the bolts are that hold the O-200 case and rubber bushings to a J-3 mount? I ordered a mount and O-200 bushing kit from Univair and they sent me a C-85 bushing kit. When I called, they first insisted that the two were identical, then after a few hours backpedaled and sent me an O-200 bushing set. However, they duplicated the C-85 bolts in the second delivery. When I called today, we went through the routine again, but this time they insisted that the bolts are the same length for both the C-85 and the O-200 installation even though the front to rear distance through the O-200 case and bushings is much longer (you can't compress the O-200 bushings enough to pass this bolt through them, the case, and the mount, much less have enough bolt showing through to capture a nut thread and start tightening. Quite frustrating.
JimC
JimC
