Laz
Girdwood, AK.
I'm about to install a set of float fittings on a 2+2 and have some questions.
I've built a weld- on set from the Northland CD, but haven't decided on what to do for the cross brace tabs(wires)? I've seen two styles of tabs on 18s and Pa12s. The single ear tab as on the CD and a "two ear" tab on 12s. Does one have an advantage or is it related to float manufacturer?
Also, how critical is the the hole alignment (main struts now) from left to right fittings? Do they need to be exactly parallel to each other like wing fittings or is there some play in the strut attachments?
Thanks, Laz
Thanks, Laz
