Results 1 to 6 of 6
Thread: Voltage regulator location
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Does anyone have drawings to relocate the voltage regulator when
    installing ECI's angled spin-on oil filter mod (O-320)?
    Nick
    Tom's Avatar
    May 2003
    Bettendorf, Iowa
    169
    voltage regulator relocate
    I don't have any drawings but I'll try to find a picture of the mounting bracket that I made and the new location for the regulator on the right hand side of the panel.
    Tom from Iowa
    Tom's Avatar
    May 2003
    Bettendorf, Iowa
    169
    Picture is now in the Photo Gallery
    OK, I found the picture that shows you what I did. Go to Photo gallery/ members album/t/tom and you will fine a picture that might help.
    I installed the B&C filter conversion at the last annual inspection and had the same interference problem to which others have referred. I made a drawing on the back of a cardboard box that I tossed when the bracket was completed. I made the bracket while the A&P/IA was cobbling oil lines. He was impressed with the concept and the rest is history......
    Good Luck getting the bolts out of the original bracket, and don't drop them on the inside of the fuselage where they could get lodged where you don't want them.
    Tom
    21,180
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Thanks, Tom, Steve. Tom, a few more Qs:
    1. What did you attach the bracket to the F/W with (e.g. 3/16" bolts)? My VR is mounted on two rubber mounts bolted to F/W with four 1/4" bolts/nuts.
    2. Were you able to clear the fresh air intake box?
    3. Did you re-route the shielded bat wire to your electrical panel, or just replaced it with a longer one? (Can't see any cabling running right to left along the F/W, so my guess is you went straight back somewhere under the VR).
    Nick
    Tom's Avatar
    May 2003
    Bettendorf, Iowa
    169
    Update
    1) The bracket was primed and painted, then attached to the firewall with 3/16" bolts. The voltage regulator is attached using some rubber washers that you can barely see in the picture.
    2) Yes, we were able to clear the air intake box. It is a tight fit, however.
    3) I will need to look at the wire routing again. The A&P/IA did that work while I was away on business. I will look next week if I get a chance.
    Tom
  1. Replacing voltage regulator.
    By Cub X in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 08-18-2016, 11:04 AM
  2. 320 Voltage Regulator
    By Nick Saum in forum Modifications
    Last Post: 06-03-2009, 10:20 PM
