Food for thought on Compression Test.......
On another note I am well into my annual condition inspection. This year I had a leaking exhaust valve. Staking it helped and a borescope inspection indicated crud on the valve seat. We were able to lap it in situ (in place) which cleaned up the seat and restored the compression. I then went out and got my own borescope so I could inspect all valves and cylinders. I got the Vividia 980 model. In the process of looking at the internet I found this by Mike Busch via AOPA and thought it had some really interesting stuff that I was very surprised by.........
One pervasive old wives’ tale has it that compression readings in the high 70s are excellent, in the low 70s are good, in the high 60s are marginal, in the low 60s are poor, and anything below 60/80 is unairworthy. Another widely accepted old wives’ tale is that an engine with compressions in the low 60s is a “tired engine” that will not put out full rated horsepower. Both are dead wrong.
More than three decades ago, Continental Motors issued a service bulletin (M84-15) debunking the first of these superstitions by establishing a new go/no-go criterion for compression tests: the master orifice tool. Mechanics who followed this guidance were astonished to find that compression readings in the low- to mid-40s were deemed acceptable by Continental.
This 1984 guidance was based on a series of engineering studies performed using an IO-550 engine mounted in the dynamometer test cell at the Continental factory in Mobile, Alabama. Those studies revealed that when the compression ring gaps on the IO-550’s pistons were filed oversize intentionally to reduce the compression of all six cylinders to 40/80, there was no measurable loss of horsepower output (although there was an increase in oil consumption). This effectively debunked the “tired engine” old wives’ tale.
Enter the borescope
Nineteen years later, Continental threw mechanics another curveball by issuing Service Bulletin SB03-3 (which superseded M84-15), directing that a borescope inspection of each cylinder be performed at each annual and 100-hour inspection, and any other time that a compression test is done. It further made it clear that the borescope, not the compression tester, was to be the gold standard for assessing the airworthiness of a cylinder. It directed that if a cylinder flunks a compression test but the borescope reveals no obvious cause for the low compression, then the engine is to be flown for at least 45 minutes and the compression test be redone. Only if a cylinder flunks its compression test twice in a row (with at least 45 minutes of flying in between) is it deemed unairworthy.
Continental’s SB03-3 was pretty shocking to mechanics when it was first published in March 2003. In those days, few GA maintenance shops owned a borescope (unless they did a lot of turbine work), and there was no training available to mechanics on how to use one to inspect a piston aircraft engine cylinder. Most A&P schools still don’t teach anything about how to use borescopes in piston engine maintenance.
The service bulletin recommended using a low-cost rigid optical borescope—the Lenox Autoscope, which was so named because it was designed for automotive use, and at more than $2,000 was one-tenth the cost of the fiber-optic borescopes being used for turbine engine hot-section inspections. Still, lots of mechanics and small GA maintenance shops were not amused by being told that they had to shell out two large to buy one of these instruments. Fourteen years later, some A&Ps still don’t own a borescope.I was an early adopter of borescopy. Having gone through the painful experience of pulling cylinders because of low compression readings, only to find nothing physically wrong with them, I was anxious to adopt this more enlightened way of evaluating cylinder condition. I borrowed a Lenox Autoscope from a shop on my field and began inspecting the 12 cylinders on my Cessna 310. It was an eye-opening experience, almost as if I could climb inside each combustion chamber—or at least stuff one eyeball inside. Over the years, the compression test has proved untrustworthy and prone to false positives, resulting in tens of thousands of cylinders being removed unnecessarily (including a few of mine). That’s why the SB03-3 guidance calls for any disqualifying compression test that is not corroborated by borescope evidence be retested after flying for at least 45 minutes. That’s excellent advice. I’ve seen many cases where a cylinder that flunked the first compression test easily passed the second one. In one notable case involving a Cirrus SR22, a cylinder that tested at 38/80 (and that the shop doing the annual wanted to yank) wound up measuring 72/80 on the retest after a one-hour flight.
SB03-3 did not go so far as to recommend that borescope inspections should replace the venerable compression test. Continental couldn’t do that, because the requirement to perform a compression test is written into the FARs (Part 43, Appendix D). But SB03-3 did all it could to convey that Continental is no big fan of the compression test for determining cylinder airworthiness. (A senior Continental executive once confessed to me that if they could’ve dropped the compression test altogether, they would have.)
Hope this helps
