Results 1 to 2 of 2
Thread: Leaning
    375handh's Avatar
    Feb 2004
    Santa Rosa, CA
    214
    Leaning
    I have a bit of an unusual problem that I thought I would see if any of you might have some good information on. I have a PA-18-150. It had its annual about 100 hours ago. Last couple of flights I have taken, when I lean as normal (don't have any gauges, just the old fashioned way), I have after awhile lost a little power like maybe carb icing. When I turn the carb heat on I get a 300-400 RPM drop and it just stays there. I played around with it a lot but the only thing that corrected the problem was just to go full rich; everything functions fine then. This is in California so still pretty warm and wide temperature dew point spread.
    Anyone have any idea what's going on?
    Thanks.
    375handh
    njneer's Avatar
    Oct 2004
    Chugiak, Alaska
    94
    I had "unusual" problems with mixture and throttle settings on a PA-18-150; things like RPM increases when I added carb heat, unexplained RPM changes (up or down, +/- 100-300 RPM) while in cruise configuration and such. Turns out, the screws attaching the bowl to the bottom of the carb had loosened. Grab the air filter and give it a shake, if it wiggles, you may have a similar problem. The mechanic explained that when the gasket is replaced between the bowl and the carb, the screws have to be tightened and then re-tightened after 24 hours after the gasket compresses. If it wasn't done properly, the problem can manifest itself a long time after the work was completed.
    Njneer
    Life in Alaska isn't always easy, but it has its rewards.
  1. Proper Leaning Techniques
    By WindOnHisNose in forum Cafe Supercub
    Last Post: 03-22-2010, 02:29 PM
  2. Art of leaning and carb heat
    By BritishCubBloke in forum The Art and Science of Flying
    Last Post: 07-06-2003, 10:24 PM
