Results 1 to 10 of 10
Thread: PA-18 Fuel Valve Sticking
    San Antonio, TX
    12
    Fuel valve is difficult to turn. With cap, gaskets, spring, indent washer removed. valve stem wiggles and turns easily, but stem won't pull out. What is the procedure to remove stem and lubricate?
    20,643
    After all the parts are removed put the handle back on and pull. Should come out fairly easy. The new valve from Univair is a very nice replacement and it isn't a brass cone running in a brass seat. If you are going to repair yours use a light valve grinding compound if the cone is scored and lubricate with fuel lube.
    San Antonio, TX
    12
    I have tried this, but still unable to pull out. The stem has some in and out play, maybe 1/32" when I pull as hard as I can. How rough can I get?
    S2D's Avatar
    Montana
    4,253
    Probably galled to the point you are going to have to get real rough. Pull hard while twisting.Then Plan on replacing it with Univairs. (Best get Univairs first if you don't want to be down for long)
    cubunltd's Avatar
    Mar 2004
    Belle Vernon,PA
    1,138
    If it's stuck in there that hard, you'd be better off with the Univair valve. Lapping works to a degree, but if you lap too much the cone goes too deep into the housing and you loose tha detent action.
    cubsunlimited2verizon.net.
    M1's Avatar
    Jul 2002
    Vancouver BC Canada
    390
    Just replace the original valve with the Univar valve.
    jk's Avatar
    Dec 2002
    over there
    480
    Amen to the above...GO Univair ...SWEET..just remember to get the extra nipple to retro from original for clearance.
    Clearwater,Fl
    2,578
    Is the Univair model equal to the late 18 out of vero beach. I liked that one with the indents. very smooth and definit.
    San Antonio, TX
    12
    Thanks for everyones help. The original fuel valve is now lubricated and working. I made a "dent puller" out of tubing with a machine screw welded to the end. I screwed in where the handle fastens and the stem popped out on the first try. It was in surprisingly good shape for probably not having maintenance for 45 years.
    May 2004
    Dublin Ireland
    20
    i have the same prob with a very stiff fuel valve.....univair here we go.
    1957 PA18 A
    Dublin
    Ireland
  1. fuel valve
    By M1 in forum Super Cub Sick Bay
    Last Post: 04-10-2016, 05:06 PM
  2. Fuel Valve Screws...
    By tamarack in forum Cafe Supercub
    Last Post: 12-12-2009, 12:34 AM
  3. Andair Fuel Valve
    By C-YQK in forum Modifications
    Last Post: 09-04-2005, 06:26 PM
