flattopplayr
If im correct, this engine would not have any lag time or spool up time. It is not a split turbine such as in a garret or a PT-6 engine. It is a single shaft turbine, like in the C-130 Allison Engine. It should be ran at 100% through all phases of flight, thus when you shove the power in all you are doing is changing the pitch of the prop. We have this on the Herc, and boy, you talk about instant thrust!!!!
Would be great on a bush plane!!
