Gordon Misch
MEMBER
TJ, don't tell my wife I'm that old; she'll want to trade me in!!
bob turner said:You may maintain that data should always be taken in zero wind, but you will also note that my data is the only data that specifies the wind. How do you know, for instance, what the winds were when Mark Drath tested?
S2D said:Supercub- +/-150 HP Borer prop, Standard gear, 30" bushwheels VG's
50 deg 5mph wind surface Pavement, 34 gal fuel, 175 lb pilot, 40 lbs junk in baggage.
Before 195 feet
After 159 feet
decrease 36 ft ( 18.5%)
and that my friend is pure bull$hit which almost everyone on here agrees with.bob turner said:and that I had before and after data
SuperCub MD said:Mark called and said there was some crying going on because I didn't post "hard" numbers in my initial testing of the thrust line. I dug out my notes, so here you go.
Average of half dozen take offs with the stock TL,
186.33 feet
Average of half dozen takeoffs with the zero TL,
150.25 feet
This was done in a basic stock mid-sixties PA18-150 with Borer and Bushwheels. It was not my own Cub, but one I had flown enough to feel comfortable with out on the edge. The usual tail up, pop full flap at rotation short field technique was used. Temp was warm, wind was light. Tape was stretched straight into the wind and spotters used to make the measurements. The TL change was done as quick as humanly possible, the before and after tests were about a hour apart in a attempt to keep the conditions the same. If anything, the temp rose slightly and the wind fell slightly between tests so no environmental advantage can be given to the zero TL. I've tried to do a lot of this testing stuff over the years, and environmental changes make a huge difference in these Cubs when you are splitting hairs down to feet and inches. Different Cub, different pilot, slightly different wind/temp and results will always vary.
FlyingY said:i'm sure if i searched this forum i could find out what you mean.....but what exactly do I need to measure?? what are the tolerances or measurements I'll be looking for?? thanks for your help.
12 Geezer said:Bob wrote: "I spent six hours the last two days in a Thrustline Cub, hands-off"
Jeeze, Bob - try it hands-on - - maybe that's why you keep saying you can't feel the plane - - ya gotta touch it first!!!
S2D said:12 Geezer said:Bob wrote: "I spent six hours the last two days in a Thrustline Cub, hands-off"
He was probably the instructor. ( in the back sleeping)
bob turner said:I was in the front, heat on.
aktango58 said:Did you include a diet? :lol:
Maybe the 'front lobes' that needed flattened were on a different can, I mean cam...
(hey, I resemble that comment)
