supercubdriver
Good morning
What would be the pros and cons of replacing the tail wheel spring on my supercub with a heavier duty 13/4"(?). I have a Scott 3200 tail wheel. By doing this, will it create more stress on the airframe? Is it an easy change over? This thought originated because of the shimmy problem discussed previously on this website. After I tightened the nuts up some, I did notice that the angle of the post bolt was not the recommended angle but the shimmy did not happen on the last few landings.
