B
barkerlongez
Hi folks --
I need some advice on leveling a PA-12 --- I know the plumb bob way from the door post to the fuselage dimple --- but I rebuilt my door frame and forgot to put in the screw hole that is in the upper door frame.
Any advice on other good leveling points -- then I can put the screw hole back.
I think the bottom of the butt rib should be a good fore/aft level, but is there a good side to side level point, such as the upper windshield cross tube? Or how about a level across the lifting tabs on the wing root?
thanks
Mark
thanks
Mark
