BENEFACTOR
I am making new cables for a Super Cub and have run into a problem and was wondering if anyone else has ever run into this. I ordered new AN161-16LS turnbuckle forks to attach the turnbuckle to the aileron horn. The problem is the fork is to short to get the clevis bolt in. From the center of the hole to the "Y" is 3/8" on the new ones and 1/2" on the old ones. I called Wicks A/C and asked about the MS21252 which uses a locking clip instead of saftey wire, he laid the two on top of each other and said there was no difference. I order some from another supplier to check for myself. Has anyone else run into this?
