paul romine
indy
With metal ribs, is there a preference to rib stich or rivets?
yup (actually they ruin them when you put them in)-- shouild never rivet or martin clip a truss rib. If you've ever seen how bad it screws them up, you'd never do it again. One area the FAA should issue an AD on. (just my opinion, do whatever you feel comfortable with)behindpropellers said:Do the pop rivets ruin the ribs when you go to take them out?
green horn said:I happen to own and operate a 2005 CC TOP CUB, The wings are most definitely rib stitched and the workmanship is top notch. I believe that rib stitching is the best way to go as it helps distribute the load between the upper and lower portion of the rib. Also, how many times can you put holes in a rib recovering with rivets? AS is often the case in life, the fast way is not always the best way. MY two cents...
