Clayton Harper
MEMBER
WdaH?One more reason I refuse to do Ceconite cover jobs. No more dope!
The FAA issued an AD on the Maules a few years ago after they had two seperate accidents like this. Color coded the cables at the elevators and the bellcrank.
ok .... someone go measure at what temp you need to get butyrate dope plane up to to start a fire.....
fires start because of spilled fuel VAPORS on hot or sparking stuff... it will not mater if your plane is covered in water, fabric or aluminum, or DOPE!!!!!
The plane took off with both ailerons swinging in the same direction i.e. left roll input = both ailerons up, right roll input = both ailerons down.
