I use stainless steel fishing leader. Berkley 60# .032 or 90lb .050, comes in a 60' roll for making custom steel fishing leaders. It's plastic coated so it slides through the guides real easy. It can be purchased at any of the major sporting goods stores.
They also make matching SS sleeves for crimping a loop.
Hey forum, my trim pointer is missing. What is used for the pointer that protrudes through the panel and indicates stabilizer position? Have tried multiple searches on different sites, but must be using wrong terminology. Thank you!
Thanks, Mike. This one is for a PA 20 and PA 22 and it appears to be aligned vertically in the cockpit. So I'm not sure it's the correct part, since the Super Cub trip indicator panel is aligned horizontally.
